- Location
- United States
I have a 2004 GX470 for sale:
FRONT (JULY 2019)
9.13.2004 9.081 miles 5,000 mile service performed
7.27.2005 14,373 recommended maintenance performed
12.7.05 19,964 5,000 mile service performed
5.11.2006 24,858 5,000 mile service performed
7.25.2006 30,118 recommended service performed
9.20.2006 30,000 mile service performed
10.20.2006 35,021 5,000 mile service performed
1.8.2007 39,810 5,000 mile service performed
8.10.2007 5,000 mile service performed
12.4.2007 54,961 5,000 mile service performed, diffs checked
4.2.2008 59,877 recommended maint. Performed
8.21.2008 64,889 5,000 mile service performed
2.11.2009 69,653 5,000 mile service performed A/C system serviced
6.29.2009 74,856 recommended maintenance performed, fuel system serviced, fuel injection system serviced
11.23.2009 79,967 5,000 mile maintenance performed
5.11.2010 85,223 5,000 mile maintenance performed. Suspension lubricated.
10.13.2010 89,883 90,000 mile service performed, drive belts checked.
1.11.2011 94,994 vehicle serviced
5.16.2011 99746 vehicle serviced
8.16.2011 102,720 vehicle serviced
9.26.2011 vehicle serviced
3.29.2012 112179 water pump replaced, radiator replaced
5.17.2012 114934 recommended main. Performed 120,230 120,000 mile service performed including drive belt check, engine checked, driveshaft serviced, front and rear diff fluid changed, spark plugs replaced, transfer case serviced.
2.19.2013 124,696 recommended main. Performed
5.22.2013 129.998 recommended main performed
19.7.2013 134,839 drive belts checked, diff fluid checked, driveshaft checked, inspection completed
2.24.2014 140,341 recommended maint performed
5.21.2014 145,226 recommended maint performed
9.29.2014 149,662 150k maint performed
8.7.2015 159,839 recommended maint performed. Cv boots replaced, cylinder head gaskets replaced
3.30.2016 169,849 recommended maint performed recommended maint performed. Fuel linjection system flushed
5.24.2016 173,363 cv boots replaced
6.22.2016 recommend maint. Performed
9.19.2016 179783 90kservie performed including timing belt replacement
12.19.2016 184,529 5,000 mile service perfomed
2.23.2017 187828 oil and filter changed
Replaced around July 2019:
MOOG FRONT LOWER CONTROL ARMS
MOOG FONT LOWER BALL JOINTS
WHITELINE FRONT CONTROL ARM BUSHINGS
STOPTECH CETNRIC FRONT AND REAER CALIPERS
STOPTECH FRONT AND REAR PREIMUM ROTORS
$16,000 Clean Texas Title located in NW Houston 832 732 5205
FRONT (JULY 2019)
- DOBINSONS 2.5 MMR EXTENDED TRAVEL COILOVERS WITH RESEVOIRS JULY 2018
- JBA UPPER CONTROL ARMS FEB 2019
- DOBINSONS HEAVY LONG TRAVEL SPRINGS
- DOBINSONS LONG TRAVEL 2.5 SHOCKS WITH RESEVOIRS
- DOBINSONS PANHARD BAR
- DOBINSONS UPPER AND LOWER LINKS
- **8.2” 3.73 FJ/4RUNNER AXLE HOUSING WITH ELOCKER THIRD MEMBER
- LIL B BUMPER WITH WINCH CAPABILITY
- RAGO FAB DITCH BRACKETS
- RRW SLIDERS
- Prinsu Roof Rack
- Rear Swing out
- (5) NITTO RIDGE GRAPPLERS
- (5) RRW RR2-V WHEELS
- QUICKSAND WRAP (SILVER PAINT UNDERNEATH) : AVERY DENNISON 50MIL SANDSTORM
- INTERIOR CARPET REMOVED, COMPLETE SOUND DEADENING INSTALLED (CARPET REINSTALLED)
- ALL SERVICE RECORDS AVAILABLE THROUGH CARFAX AND LEXUS. ALL MAINTENANCE PERFORMED AT CORRECT INTERVALS INCLDING TB/WP, VALVE COVER GASKET(S), HEAD GASKET(S), ETC.
- INTERIOR IS 9/10. NO DASH CRACKS
- CVS ARE GOOD. Driver CV outer boot has some seepage. TIE RODS ARE GOOD.
- MILEAGE 230k (NOT A DAILY DRIVER. SITS IN GARAGE)
- TOTAL CHAOS CAM TAB GUSSETS INSTALLED MARCH 2019
- DRIVE SHAFT UJOINTS REPLACED FEB 2019
- DRIVER SIDE AXLE SEAL REPLACED FEB 2019
- PREVIOUS OWNDER HAD ALL THE CARPET REMOVED AND SHAMPOOED. WHILE INTERIOR WAS REMOVED, SOUND DEADENING WAS INSTALLED. THE GX IS DEAD QUITE ON THE ROAD.
- MAINTENANCE
