- Location
- United States
TRD Supercharger with a UDR piggy back ecu, TRD boost gauge that was put into the A pillar and looks factory, the OEM DVD player in the the rear was replaced with a iPad holder that folds down and you slide your iPad in (it charges it as well as allows you to use infrared headphones), looks factory. It's got an LED bar on the front, PIAA lights in the front bumper. all speakers were replaced with infinitys, rear sub taken out and a digital infinity amp was hidden in there. the sub is now a hardshell 10" pioneer that can be moved around if needed. Has sirius and handsfree bluetooth that is built into the touch screen Nav. Has a 1200w inverter wired and hidden in the rear. It's got Nav with the most updated disk, front and rear air. The truck has 170K on it, the Supercharger has 30K on it.
The UnderDogRacing ecu is the top of the line ecu and can program the mixtures wirelessly.
Bump It Offroad - front bumper, sliders, diff drop and dual swing out rear bumper with rotopak holder. I had the rear bumper coated with zinc powder coating. The front bumper could be repoweder coated to make it perfect.
TJM XGS Gold edition shocks
Iron Man torsion bars
OME 863 springs
Warn M12000 winch with new synthetic cable
CV axles replaced with OEM
Snorkel
Complete high flow exhaust - stainless
high flow fuel pump
LED interior lighting
powered coated wheels (5)
new brakes and rotors
new front end and repacked new bearings
basically anything that needed to be done on the truck was done. I just did a cooling system flush. I know I am missing a lot of things I've done to it but it is truly a solid truck, with zero issues.
There are things that aren't perfect. The front bumper I was going to have repoweder coated. I don't believe it was done properly the first go around. The front DS seat has some stitching coming apart. I believe its an easy fix. There are a few scratches on the outside of the truck, one scratch that came from my hilift falling over.
Price $18.5
OME 863 springs
Snorkel
high flow fuel pump
Price $18.5
