2000 LC Turn Signal/Side Marker connectors
I have a 2000 LC and I want to connect TurnSignal wires to LEDs I now have embedded in my Depo Fog Lamp modules.
I need a wiring adapter for the Turn Signal/Side Marker wiring. I would rather not splice into vehicle existing wire harness so I’m asking if an adapter is available(I can make it my self if I had the right M/F connectors & contacts) or even better the mating connectors with pigtails if they exists. I believe the part # for the female connector(pics _369, _580) is 90980-11020 but of course I would then also need contacts.
Anyone no the part # for the mating connector(pic _612) ?
or whre I can get these connectors with pigtails already wired?
I'm not sure about the specific connectors for the LC. But on many other vehicles, I have made my own, but converting factory connectors to either weather pack, Deutsch, Metri pack connectors. (I mean cut out the factory connector and insert one of these in there. They are rebuildable, expandable, and standardized (as long as you stay within type/brand). I believe that some manufacturers use the connectors throughout the years. Yes, a bit expensive to initially get, but when you can change a 4 pack connector to a 6 pack because you just wired in another component....awesome. I get my stuff here mostly http://www.delcity.net/store/Wire-Connectors-&-Quick-Splices/ Note that these only "really" work when they are in the middle of a wire set....they won't work if there is a specific connector thats hard mounted into a component.
