1pz Swap with 1hz engine
My pz was made in japan. But i use it in mozambique(africa) is from 1990. And i have prop shafts of 1hz, if necessary im going to change my 1pz prop shaft with 1hz prop shaft. Is it possible to cut a prop shaft and weld?
Yes you can shorten a shaft but it must be cut at the either end and re balanced afterwards. If you have 1HZ shafts they should fit no problem. Any mods to a shaft should be carried out by an engineering shop which can balance them properly because any in balance will make it feel like a washing machine and will cause damage to transfer box and diffs.
Hi. I would like to know if is it possible to Swap 1pz engine(4speed gearbox) with 1hz engine(5speed gearbox).
Is the 4sp a R141?
It is on a plate on the firewall.
