For Sale 1HZ Turboglide Kit - Menlo Park, CA
Truckee, CA
Selling a used 1HZ turbo kit from TurboGlide in Australia
The kit has been on my truck for about 1500 miles. It is in perfect condition.
Kit includes:
-turbo
-adapter to 1HZ stock manifold (no need to even remove manifold to install turbo)
-Air filter to turbo pipe adapter
-Turbo to stock 1HZ cross-over adapter
-braided steel oil supply line
-"T" adapter from block to oil line (accepts oil line and oil sending unit)
-Oil drain hose
-5 -bolt exhaust adapter
I will also include the first 6" or so of exhaust if it helps you adapt. I was running 3" exhaust.
This kit is in perfect condition. Turboglide has sold thousands of these kits. Huge improvement over the stock 1HZ. This kit is very easy to install; You should be able to bolt everything up in a couple hours. You will need to adapt your exhaust.
edit: sale pending.
