I have a 1HZ diesel that has had low compression in the #1 cylinder since it arrived from AU. It had been sitting around for two years before I purchased it. #1 compression is 430 psi (hot and cold) and rises to 480 psi with a squirt of oil in the cylinder. All other cylinders are 575-600 psi. The engine would put out lots of white smoke at start up for about 10 minutes until warm, then burn clean. If I crack the #1 injector union nut (to stop fuel to the #1 cylinder), the white smoke problem vanishes immediately. It burns no oil in 3000 miles.
I pulled the head and dropped the oil pan expecting to find a broken or stuck piston ring in #1. Instead I found a very healthy looking set of rings and a clean cylinder bore with no sign of abrasion or scoring on the wall. Head gasket looked normal. There were some heavy carbon deposits on the cylinder wall above the piston travel and some carbon on the glow plug. I'm not sure what to do except hone the cylinder, rebuild the head and slap it back together. Any suggestions?? Thanks
