1HZ 75 series: Starting issues after engine is hot
Japan
Current issue:
When the engine is hot after driving it will not start up again till after its cooled down. Cold starts are quick and painless, after it sits about 10-15 minutes it starts normally. I am guessing there is something up with the injector pump but would love to hear other ideas that are not as costly. Haven't felt any issues when driving, the only issue is after its hot.
Thanks again for the help.
Points to injector pump being worn. Tolerances open up when hot and the ip can not create the pressures need to crack the injectors. Next time this happens, pour cold water over the injection pump to confirm.
