1HD-FTE injector nozzle holder seal replacement
Hungary - EU
Hello All!
I'm in the process of replacing the manifold gaskets & injector lines on my FTE, and ordered a set of these seals, circled red in the picture.
Now after pulling the injectors lines and the manifold I can see that there is some dirt near the lip of the seal, and probably inside of it as well. I don't think there is a way I can clean it up at this point (with the injectors disconnected from the feed) without pushing dirt into the injectors. Is it okay to just pull these seals (and hopefully it will pull the dirt with it), then try to carefully clean the area with the seal removed, then reinstall the new seals? I can see how this might push dirt into the injectors and/or the rocker area. Or should I just leave it alone & not replace these seals? I hope I've explained it correctly, my english is bad, sorry.
Thanks in advance!
