Need some help. What you know, what you think, what you suggest. Especially folks from AUS/UK.
I own a very low miles/km 1HD-FTE imported by Marv Spector some years ago. Sourced from a Toyota breaker/salvage yard in Japan, likely out of a factory test HDJ100 prior to release of that model. The motor is super clean and complete. It presents as new, having been stored by a detail-oriented engineer owner.
Considering an install in a suitable recipient, probably a 7X of some sort. I understand the differences between motors thanks to Tor, Yan and Wayne. There are several swaps documented on MUD and I understand much of what is needed to make this work - lots of sensors and work-arounds to deal with a factory ECM not open to "reprogramming" to deal with security fob, auto trans, etc. (I will use an H55F).
Here are some questions to kick it off:
Experience, insight and wise counsel much appreciated.
- Any other 1HD-FTE swaps out there, into non-original bodies?
- What issues did you run into?
- Did you use intercooler, piggy-back chip, etc?
- What results?
- Did you use the 100 ECM/harness or 78/79 ECM/harness?
- Keep or toss EGR? Heater screen? Shut down flapper?
- Upgraded turbo?
