For Sale 1996 Toyota 4Runner 4x4, Heavily Modified (SoCal/Phoenix)
Up for sale is my 1 owner 1996 Toyota 4Runner. This car was built in February of 1996. My Dad purchased it from Toyota of Escondido in April 1996. A few months later in July, I was born. This is the vehicle that drove me home from the hospital and the vehicle I drove to high school and college. Which is pretty cool. This thing means a lot to me and I’ve put countless amounts of money, blood, sweat, and tears.
The reason for the sale is simply I need something different. This truck deserves to be driven around town and shown off. Driven to the desert and driven hard. I simply don’t have that kind of time anymore. I’m driving around 18,000 miles a year driving from San Diego to college in Phoenix and back. I need to be driving something I don’t care about putting that many miles on.
Basic Specs:
1996 Toyota 4Runner 4x4 SR5
5-Speed Manual
Evergreen Pearl
Blue/Grey Cloth Interior
193,xxx miles
Although this truck does have nearly 200,000 miles on it, almost every single nut and bolt has been gone over or replaced. At 176,000 miles, I had the motor replaced with a 92k mile motor and every single seal was replaced inside the engine, including timing belt and water pump. Here’s the rest of the maintenance history since I started driving it. We still have all service receipts since new in a folder that I will include with the car.
Maintenance
-02/02/12 New Rear Drum Brakes
-03/31/12 Repainted Evergreen Pearl
-05/12/12 157,299 miles New front rotors
-07/26/12 158,623 New Clutch Master Cylinder and Slave Cylinder
-159,500 New Toyota Fuel Filter
-159,500 Oil Change with Toyota Oil filter
-159,500 New Toyota PCV Valve
-159,500 All new fluids in both differentials, the transmission, and transfer case
-159,500 New air filter
-159,500 New Borla XR-1 Muffler
-159,500 Spark plugs and wires replaced with new NGK ones
-159,500 Throttle Body and MAF cleaned
-162,500 Oil Change with Toyota Oil Filter
-163,684 New Front Brake pads
-164,444 Newly rebuilt passenger head installed and new head gaskets
-165,400 New Air Filter
-167,362 New Starter Contacts and Sunroof Motor
-05/29/13 New Power Steering Pump Bearing/Seal and fluid flush
-07/23/13 New Suspension
-07/27/13 New Tires
-07/29/13 New Clutch Master Cylinder
-168,500 Oil Change
-168,600 Alignment at The Truck Shop in Miramar
-169,000 Tire Rotation
-169,000 New Rear Main Seal
-169,000 New Flywheel
-169,000 New shifter bushings
-169,000 New clutch disc
-169,000 New pressure plate
-169,000 New pilot bearing
-169,000 New release bearing
-172,000 New Hella Horns
-172,000 New Front Sway Bar Bushings
-172,220 Oil Change
-172,562 New Outer Tie Rods
-172,562 Reman'd Power Steering Rack
-172,562 Power Steering Fluid Flush
-172,562 Alignment
-173,148 Coolant Flush
-173,148 Thermostat and T-Stat Gasket Installed
-175,000 Rear Hatch Lift Struts Replaced
-175,500 New Toyota Lower Ball Joints installed
-175,500 Used Camburg Uni-Ball Upper Control Arms Installed (8,000 miles old)
-175,900 Oil Change
-175,900 Tire Rotation
-177,154 Engine #2 Installed
Mileage of Engine #2 on time of install 92,000 miles
New Toyota Genuine Parts installed at install of Engine #2
-6 Rebuilt Injectors
-Water Pump
-Thermostat and Gasket
-Timing Belt
-2 Timing Belt Idler Bearings
-6 Spark Plugs
-2 Camshaft Seals
-2 Crankshaft Seals
-Oil Filter
-Release Bearing
-Valve Cover Seal Washer
-6 Spark Plug Seals
-2 Valve Cover Gaskets
-PCV Valve and Grommet
-3 Belts
-Oil Pan
-178,250 Safari Steering Rack Installed
-178,250 Power Steering Fluid Flush
-178,250 Alignment
-180,000 Air Filter
-180,000 Diehard platinum Battery installed
-181,800 Alignment
-182,288 Oil Change
-182,288 Coolant Bypass Pipe
-185,555 Brakes bled
-185,555 Oil Change
-186,700 Tires Balanced
-188,400 New Front diff oil
-188,400 New Driver CV Axle
-188,400 4 New Toytec Coilover bushings
-190,000 ADS Coilovers Installed
-191,600 Alignment
-192,000 New Air Filter
-192,000 Oil Change
-192,000 Re-sealed Rear Diff
-192,500 5 New Goodyear MTR’s installed
-192,500 Icon Rear Shocks rebuilt
-193,000 New Brakes
-193,000 Alignment
Off Road Modifications Include:
Re-Painted Evergreen Pearl
Toytec Front Coilovers (Replaced)
Superflex Rear Springs
Deckplate Mod
Kenwood Radio
Weather-Tech Floorliners
Borla Muffler
ARB Compressor
Yukon Grizzly Zip Air Rear Locker
315/75/r16 Goodyear MTR’s with Kevlar
Savage Off-Road Sliders
Savage Off-Road Front Bumper
Savage Off-Road Full Skid Plates
Camburg Uni-ball Upper Control Arms
Any7 Off-Road Gas Tank Skid
Toytec Rear Adjustable UCA’s
Custom Rear Adjustable LCA's
Wheeler's Front Superbumps
Big 3 Upgrade
Icon 2.5 rear shocks with piggyback Resi
Savage Off-Road Rear Bumper with Swing-out
ADS 2.5 Coilovers with Reservoirs
Truck is located Tempe, AZ or San Diego, CA. I can make either location work. If you want to fly in, I’ll be happy to pick you up from the airport, or do whatever you need.
Asking $15k obo. Might trade for an 80 or 100 series.
If you have any questions feel free to email me at:
Rhoades.Connor@gmail.com
DSC_0094 by Connor Rhoades, on Flickr
DSC_0097 by Connor Rhoades, on Flickr
Untitled by Connor Rhoades, on Flickr
