1996 fzj80
The Grove
Figured I would try to keep it local first. My 80 has to go. It shows its age in the paint but is still very solid. Factory lockers x3. Arb front with 9000lb warn winch and hella 70ff's. j's and l's with 285 bfg all terrains. I have a homemade roof rack and storage system to go with it. 238k miles.
Fixed the oil leaks on the engine and did the plugs wires and distributor cap with dans goodies. Pioneer avic700bt with backup cam. More I can't think of. $6500
Pics
Ohh man, you're not going to get off that easy. So what's a good reason for getting rid of it?
Sent from my DroidCruiser
I'm selling my car hauler and f250 as well. I need money quickly or I'll have to dig an outhouse. Septic system decided to cease functioning. I'll have to see what sells first.
What exactly is wrong with it? Clogged up drain field? Do you have a clean out between the tank and the drain field? I had a buddy use muriatic acid to clean out the drain field and worked well after the cleaning.
I thought it might be the lines so I started to dig around and check stuff. That's when I found the hole in the side of my tank. I also have a massive shallow rooted tree that I'm sure has destroyed the lateral lines.
Let me know if you sell off the upgraded stuff you put on it. I might be interested in your ARB to replace my 1st gen Slee bumper.
Nice looking 80.
I might be interested too if you sell off any goodies like the ARB.
