For Sale 1996 1fz-fe engine and parts in San Diego CA
San Diego, CA
Hey Guys,
I'm parting out the engine I pulled from my truck. I was going to do a rebuild but lost steam. I haven't looked at the rotating mass so I don't know the condition there. I was replacing it because I found aluminum shavings in the oil pan. The upper oil pan is off a 93 so it doesn't have the crank sensor on it. I had to put that on the engine that went back into the truck. Also there is a crack in the block on the power steering ring (you can see in the picture. This happened from setting it down too hard on the ground. The block is probably scrap now.
I also have other part you can see in the pictures. If you don't see it. I'm probably using it.
I prefer pick up, but I'll ship on your dime :)
make an offer on other parts.
Bryan
Parts that have sold:
rear siderail spacer
cam chain cover
cam/PS gear
oil pump
lower cam gear
Head
valve cover
UPDATE!!!!
I pulled the crankshaft, piston assemblies (piston, con rod, cap), oil cooler and oil squirters out of the block and those are now for sale individually.
engine pics
more pictures
last pics
sidestep parts
The siderails are a bit rusty and I know people give them away, but I figured I post before I trashed them.
Miles on the motor? Do you have a transfer case?
The engine had 180,000 on it when pulled. The transmission, xfer case, intake, etc when back on the rebuilt longblock.
Bryan
newtomelx PM'ed
I don't have the plastic top pieces for the runners.
Did you want the mudflaps too?
Is that OEM Blue hub clutch fan? If it is, how much shipped to Seattle 98125
Bromo95: It's one of the bimetal clutches. I replaced it with a blue OEM.
devildogcruiser25: They came with the truck so they have 10,000 miles that I know of. I don't see any Toyota marking on them, but they worked fine when I pulled them, I was doing a HG replacement and changes out the cap, rotor and wires.
see first post for parts sold...
bump. I'm going to post it local on CL and Ebay soon, then extras may go to the scrap metal yard.
well just read the post looks like the block is just a boat anchor ill take the head though
cool, I'll PM you for details
see top post for sold parts.
UPDATE!!!!
the block and crankshaft caps are going to the scrapyard tomorrow.
No, I had to use it on the engine that went back in. sorry.
