For Sale 1995 Toyota Camry XLE - Wisconsin
Toyota Camry XLE V6. Top of the line, fully loaded with moonroof. Car purchased a couple years ago with 188,000 miles with a bad engine and transmission. Car currently has 224k.
Regular oil changes. Current blackstone oil report included along with carfax for engine, transmission, and chassis.
1) New high pressure power steering hose, brand new power steering rack and tie rod ends installed three months ago.
2) Engine replaced with 130K engine, I installed a new timing belt, water pump, cam seals, crank seal, rear main seal, and pulleys/tensioners.
3) Transmission with 125k on it also installed at the same time. Transmission came from a CA car so it looks brand new with no corrosion.
4) Replaced front seats from a low mileage car. They commonly have severe cracking and splitting.
5) Aftermarket sony head unit with aftermarket front door speakers. Aux and USB input.
6) New Toyota windshield recently installed
7) Brand new OEM drive belts
8) New battery
9) New front brake pads, new rear pads, newer rear rotors.
10) New brake lines from the rear calipers to the front prop valve
11) Newer front and rear oxygen sensors
12) New passenger side axle bracket-to-engine mount bearing. These bearings commonly seize inside the mount and the axle is stuck in the engine mount. Huge PITA to deal with. It's already done!
13) Axles have been replaced
Needs a set of tires. This car will last a very long time.
$2500 firm.
Pictures: http://lilevo.com/sell/camry/
