- Location
- United States
1995 Toyota Pickup
Extended Cab
22re 4 cylinder
5 speed manual
4x4
Good: The truck runs good and shifts fine. 4x4 works fine. It has a 4" suspension lift on it and 285 75 r16 Toyo M/Ts. The truck also has an 8,000 lb winch that comes with it and a Trail Gear winch mount. Stock 4.56 gears. New radiator, spark plugs, and oil pump.
180,XXX miles.
Bad: Has a few tree dents. Driver's seat is ripped. It had a body lift on it before that has been removed and the shifters are still extended, shifts fine though. The front crossmember on the frame needs to be reinforced for the Trail Gear winch mount.
Heres some pictures, some are from before the winch was mounted. $4,800 OBO
Extended Cab
22re 4 cylinder
5 speed manual
4x4
180,XXX miles.
