For Sale 1991 samurai 4500 FS/FT -Arizona (santanvally)
4500 OBO!I NEED THIS GONE - Would really like to trade for equil value 4runner , Land cruiser or VW(watercooled)
Tons of new stuff only 200 miles MAYBE on it.
Note* If you aren't familiar with Samurais, The Toyota axle swap allows for the vehicle to be a lot safer when lifted. Samurai's are notorious for flipping when lifted because they are top heavy. What I have done to the vehicle allows for the base to be wider and longer. The shackles were extended. Also Lifting a samurai on stock axles, with big tires is extremely stressful on the axles and can cause damage especially if you're trying to wheel. I have eliminated that problem. It also has a super heavy duty clutch just installed. You can basically wheel on it and ride it, get it hot and it will not burn up. We have soft top, and Doors for the vehicle. The cost of parts and labor for this swap are $ so make a non low ball offer thanks.
to make this 100% complete i recommend ether 6.5 tcase gear or a motor swap to take care of the underpowerd issue.
1.3 motor
webber 32/36 new gaskets - still needs tuning. runs rough some times runs fine other times im not good with carbs at all.
Electric fuel pump
New Petro works heavy duty clutch
New Petro works heavy duty presure plate
dodge motor mounts
Trail tough heavy duty trans mount
Poly transfercase bushings (cause vibes on accell)
New spark plugs 1k miles
New spark plug wires 1k miles
New cap and rotor 1k miles
Accel coil
5 speed manual trans w/1k on fresh royal purple
35x12.5x15 baja claws 95%+ tread
Steel 15x10 rims black
Yj springs
Axles - Toyota
Front frame extended 6 inches
Front axle is an 85 4runner v6 solid axle
New Ford upper front shock mounts
New Sky manufacturing Lower shock mounts
New Shocks - have box can get info.don't remember info
New Sky manufacturing complete high steer
fj80 tierod ends
4:10 gears
knuckles rebuild 1k miles
New calipers
New pads
Asin hubs rebuilt
Rear axle -toyota 88 v6 pickup
New Sky manufacturing upper shock mount relocator bar
New Sky lower shock mounts
New shocks
4:10 gears
New wheel cylinders 1k miles
New pads 1k miles
Oil 1k miles
Custom drive line just made, much larger u joints.
Body is stock uncut, no rust, it has some trail dents and dings
Custom front bumper w/ small stinger/ light bar
LED tail lights in tailgate
No rear bumper
Bikini top
full soft top - has some rips but usable
Both doors with good class -seals are meh and pass door needs door panel/windown crank
Interior
Bed linered
Nice sporty seats
Rear folding seat
Title has a brand due to the front bumper being damaged I assume by wheeling from Previous owner. the damaged area was removed with the frame extention, Would be a fun rig to drive around or complete it to be a wheeler whatever you're into. Atleast come take a look and make an offer.
<a href="http://s97.photobucket.com/albums/l201/haileyjean1/?action=view¤t=IMAG0275.jpg" target="_blank" rel="nofollow"><img src="http://i97.photobucket.com/albums/l201/haileyjean1/IMAG0275.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
<a href="http://s97.photobucket.com/albums/l201/haileyjean1/?action=view¤t=IMAG0270.jpg" target="_blank" rel="nofollow"><img src="http://i97.photobucket.com/albums/l201/haileyjean1/IMAG0270.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
We towed it down here from Oregon. Other than that we havn't put many miles on it.
<a href="http://s97.photobucket.com/albums/l201/haileyjean1/?action=view¤t=124.jpg" target="_blank" rel="nofollow"><img src="http://i97.photobucket.com/albums/l201/haileyjean1/124.jpg" border="0" alt="Photobucket"></a>
