Parting Out 1991 running FJ80 250k NorCal you come get parts
Nor Cal Pot Farm
Parting out full running rig, solid engine and trans new brake calipers and rotors 30k miles ago, aftermarket adjustable shocks engine was replaced by previous owner as was radiator and master cylinder various other parts. Lots of good stuff interior and body is rough had side impact collision on drivers doors. Broken drivers window cracked windshield and sunroof glass. Those are not due to the accident it was minor, those are due to a canoe on the roof comming lose. Did not pass smog scrapping. The exhaust leak was the cause of the failed smog I was told.
I would be down to trade whatever for a set of heads from a 2005 highlander hybrid v6 that I can put right on my highlander to do the head gaskets. The engine over heated and it blew head gasket and I was told I should plan to get new heads so I’m down to trade for a set of good heads.
If you will come pull it the engine is yours for 750, that’s without the accessories or manifold, just what you need to fix your blown motor. I will make an offer depending on how much of the electrical and fuel system you need. That would be the ecu and harness and intake sensors and injectors.
The transmission and transfer case same thing. 500 u pull em. That’s just the units not the accessories like cooler and control module or harness. I plan to sell all the electrical systems for each system compleate as well. I will make an offer depending on how much u need.
Axle set is 750 but I’ll sell those last. I need to move the truck somewhere else to part the axle set out.
I’ll start to pull parts and list them with pictures and price ASAP. I understand this isn’t an auction and I’m not trying to solicit bids just post what you need and I will post it with pictures and an offfer. I will check the tread multiple times daily. If u want to talk about a bunch of parts or arrange an trip to get bigger parts please pm me.
I have the title it was registered last year did not pass first smog test isn’t flagged as polluter just didn’t take it back for second test. The title can go with the shell and frame to someone with the axles and suspension for 1000 after I pull the rest of the parts. You have to tow it home. I may have triple A.
Conversely if someone wanted to pay me 1800 in the next two days I have triple A until the 18th, and could tow it 200 miles and sell it whole for that but as a part truck, however I will include title, and keys.
I took some pics today, should give general idea of what’s up.
