SOLD 1991 HDJ81 VX donor leftovers
Nova Scotia
I'm beginning to part out a 1991 HDJ81 that I'm using as a donor for my FJ80. Location is Halifax, Nova Scotia, Canada. I'm happy to ship.
I'll be keeping:
- Engine
- Trans
- Swap-related parts (fuel lines, start/glow relays, fuel filter, pickup, clutch pedal, etc etc.)
- Ignition/lock cylinders
- Locked axles and associated wiring/switch
- Gauge cluster
- Fog light switch
- Heated seat switches
- Altimeter
- Side window visors
- Tire carrier + tailgate
- Door shells/glass/guts
- Front/rear window stainless trim
- Mirrors
- Side mouldings
- Grille
- Taillights
- Hood
- Front quarter panels
The rest is for sale. Keeping a lot of the good stuff I know, but that's why I bough this thing as a donor. Let me know what you need! Some pics:
AC controls price ?
Rear side windows left and right complete with rubbers and trim
The rear door window complete with window molding
Seat covers
pm send
1. Front axle brake line fitting from where soft line line drops down and connects, it’s an arrowhead shaped 3-way fitting
2. Headlight washer switch
3. Mirrors and mirror control switch
Also, does it have factory sub tank? If so, all of those parts.
AC controls price ?
PM sent.
Seat covers
pm send
Rear windows are sold, rear door shell I'm leaving complete for now minus the interior card. PM sent on seat covers.
Front axle I'm keeping and leaving complete for now, mirrors as well. I have the internal frame/motor I can sell but one of the retracting mechanisms doesn't work (used the chrome shells for my FJ80). PM sent on headlight washer switch and mirror control switch.
I wish! Unfortunately not.
can i have prices for the headlight washer motor and washer bottle.
dash pad, if you are willing to separate from dash, if not whats the price on the dash?
left hand side engine bay fuse box.
radiator,
front left and right seatbelts
drivers door window control faceplate
sunroof deflector
trunk side window metal bar LH and RH side with screws
RH side rear flare( if possible exclude the part on door)
RH side rear bumper end piece, how is the condition?
RH and LH side ac vents
headlight washer nozzles
Passenger Sunvisor
shipped to 33312
thanks
do you have the passenger side side mirror minus chrome? my internals dont work. i have the retractable gear i can use from mine
radiator,
sunroof deflector
Passenger Sunvisor
shipped to 33312
thanks
PM sent
Pmed
Are you keeping the winch plate (I've got plenty of wenches already, and it'd be a PITA to ship anyway)?
Yup I am selling, willing to ship. PM sent.
Do you have a good non-airbag steering wheel?
The reason I am replacing mine is because the plastic covering is no longer "stuck" to the metal rim inside. The plastic rotates a bit around the metal rim inside and it drives me crazy. I need one that is in at least as good condition cosmetically but that is "solid" all around. Mine looks like this:
Will you be selling the air amplifier assembly? The one under the steering wheel? If so can you confirm the part number ,price and shipping cost to Los Angeles CA 90044..thanks
Did this one have cruise control? I'm after the CC module from an HDJ80, on the fender in the engine bay that runs the throttle cables.
this one has a kinda janky aftermarket cruise. You should be able to use the one from a 3FE 80 if I’m not mistaken
