1991 FJ80 In oregon rust free parting out let me know what you need.
Brake booster to 86001?
And how much for the remaining mud flaps?
Couldn't tell if you are still parting out. I have a 91 fj80 and need a few parts. The blower for the AC/Heat doesn't work when in the highest position on my rig. Do you still have the Heater/AC controls? Assuming it worked.
Need one of the switches from a rear door for the window (the electronic unit that activates window up and down).
83646
thanks,
Justin
83646
thanks,
Justin
Are you just looking for the fan switch?
I should have a good one.
I also have the blower motor assembly if you need that.
I have a drivers door master power window switch only.
Thank you
Brian
Hello,
Do you still have the front mud flaps?
how much shipped to 33122 Miami FL?
Thanks.......
Do you have hitch receiver, center caps and right side door for compartment next to the sub-woofer?
O2 Sensor Plug
Looking for the harness side plug with about 3 inches of wire still on it, passenger side (gray one). I have a new O2 but a PO cut the plug off the harness.
Shipped to 37221.
Thanks,
Matthew
Long story short, looking for the EB1 plug(both sides) on the drivers side near the 3 electrical vacuum valves. Harness side comes off the end of harness where if peaks out after the injectors. Vehicle side poked out from the vehicle harness that goes to the alternator.
Here's a pic of the plug with electrical tape on the end. It's facing the wrong direction though. Normally would point forward and connect to the plug part coming off the loom that goes to alternator.
Another pic of the area
Wire colors are: yellow/red tracer, larger yellow/red tracer and a red wire.
Thanks,
:cool:
Thanks,
:cool:
Is this part of the engine harness or the engine bay harness.
I have the complete engine bay harness and cruiser harness pulled and boxed up.
I have the engine harness still atached to the intake manifold set up with injectors.
I will not cut up the harness but if it's a section of harness that unpluges from the main harness i would sell the section of the harness.
Thank you
Brian
