For Sale 1990 Toyota 4x4 4Runner Lifted, 33 tires CHOPPED
I bought this 1990 Toyota 4runner a couple months ago. It runs great, fires right up, 4wd works. Just had the rear main seal, clutch, and differential/transfer case fluids all replaced. I am selling because I picked up a new 4runner. It has already passed smog, tags are good until May 2011. Some of you may have seen this for sale a few weeks ago, I thought I had it sold, but turns out it was a deadbeat buyer and since then I performed the above mentioned work on it. I bought this thing for 1800, put 800 into it, so I am just looking to break a little under even. Call me, names Chris 714-548-2-five-72
Info:
3.0 v6 5 Speed 139,000 miles
4wd
Procomp 4" Lift (This is a 1300.00 lift kit)
Chopped rear cab, still has rear seats though The chop appears to have been cut well, not jagged or sharp
rear tire carrier
Procomp Wheels
33X12.50 mud terrain tires (plenty of tread remaining, although they are kinda loud and vibrate)
power windows, power door locks (The doors are white because they were swapped to have power windows and door locks)
Comes with an extra transfer case in case anything crazy might happen down the line
Tags good until May 2011
Comes with lots of extra parts that you could keep as spares or sell:
Extra interior carpet
interior plastics
Extra Transfer case
2 extra doors (drives side front and rear)
Extra hood
Car runs great, fires right up. Doesn't overheat, I just replaced the thermostat, has a newer radiator, clutch has about 1000 miles on it, rear main seal was done with the clutch, idles great, runs and drives great for a 20 year old vehicle. I took it off-road a few weeks ago, popped it into 4 wheel drive and it handled like a champ. $2300
The Bad:
The A/c doesn't work
One of the rear doors doesn't respond to the power window or door lock switch
Leaking oil pan gasket
Its missing the original headliner. I do have a headliner but it is from a 4runner with the sunroof option
Its missing the plastic bezel piece around the shifter as well as the plastic kick panel on the passenger side interior floor
The radio is not currently in it, but my friend has the stock one in his garage that we can give to you
1990 Toyota 4x4 4Runner Lifted, 33 tires, extra parts, RUNS GREAT!
