1990 Sas'd 4runner - Exo - 39's
Status
Not open for further replies.
Here is the buildup:
http://www.pirate4x4.com/forum/showthread.php?t=220153
1990 Toyota SR-5 4Runner
*22RE engine recent tune up, (176,500K miles)
*Magna flow muffler
* R151 Turbo 5-speed (out of a 87 Toyota , 4.30 1st gear)
*dual 23 spline transfer cases, (crawler box has 4.7 marlin spiral cut gears>marlin installed them himself< ,main t-case has 4.0 AA gears) ,Marlin’s twin stick and custom transfer case parking brake
* custom rear CV driveline
*14” long travel front driveline
*Marlin Turtle tuff crossmember/skid plate
Axles:
* 90’ Dodge gas ¾ ton HD rear Dana 60 axle, (30 spline FF axles), drum brakes, 5.89 gearing ARB, custom top track bar mount, 2” billit alumn. wheel spacers, upgraded 9/16 wheel studs,
*78 GM ¾ ton HD Dana 44 front axle, housing has been cut/rotated (for better front driveline angle, and good castor), longside tube cut down 2.25”s, Warn axle shafts inner/outer, leftside CTM u-joint, right side Longfield u-joint, 5.89 gearing, ARB, 2” wheel spacers, HD Warn locking hubs,
*front BDS double military wrapped 3.5” lift springs for a Jeep YJ (lifetime warranty)
*custom 2” front drop box with winch points
*boomerang front shackles
*HD solid 1” dia. Tie rod/draglink
*custom 1” lift right side steering arm
*Rancho RS 9000 front adjustable shocks (the longest ones they make)
*Marlin front shock hoops
*extended front brakelines
*red top Optima battery with custom battery shut off
*a pair of rock lights
*blue l.e.d under hood lights
*Warn X800I winch with purple synthetic line, Daves off-road winch fairlead
*Dick Cepek Super Off-Roader driving lights
*custom to fit Rubicon Express Jeep TJ rear swing out spare tire carrier
*Q-78 spare tire
*17x10 AE alumn wheels
*13.5x39.5x17 SS IROK tires (85% tread left) 4wheel Parts warrenty
*rear RS 9000 9012 shocks
*rear 5.5” lift Alcan 53” long springs with custom double swing shackles and ramped front hangers
*raised gas tank (2.5”s)
* 3” bodylift
*custom rear wrap around bumper with receiver
*FULLY custom EXO cage (1 of a kind) built by Monkey Bars in Loomis
*custom sliders with 1” square inserts for steps
*Pioneer stereo/cd with 2, 4”speakers, 2, 6” speakers, 2, 6x9 speakers, 2 amps and a 10” sub
*Cobra Cb radio
*custom lowered center tranny hump
*12-Volt Guy flip rockers for off road lights/rock lights
*super clean interior
* cold a/c
*tilt
*rear heat
*int. wipers
*removable rear mud flaps
*spare parts include:
spare rear axle, spare front stock short side axle, spare rear cv driveline, spare white driver side rear door,
*********4Runner in great cond,, for being over 17 years old and a rock crawler,!!!
********* Super clean interior
*********Final rockcrawl ratio is, 4.85 to 1
*********stack of receipts
********* 6-page feature in CRAWL MAGAZINE (Issue #1 Nov/Dec 2005)
****** Winner of the 4Wheel Parts Magazine “Before and After” monthly contest
Only issues are:
1.5” dia. dent in driver side rear door (see above for spare door)
crack in front windshield on driver side (only aprox 8” up from bottom)
rear spring could use a re-arching
I am looking for $12,000.
Eric
925-586-4485
Status
