1990 FJ62 Oshkosh, WI
1990 Toyota Landcruiser FJ62 141,xxx miles $3000 OBO
All the hard work is done. I have put over $2500 in to this truck in the last two years and the way it runs and drives shows.
4.0L fuel injected straight six engine
Automatic transmission with over drive
4.10 differential gears
Rear lock right locker
Stock suspension at all corners
Front winch bumper
33x9.5r15 BFG All Terrain T/A KO’s 5 of them, 4 with 6000 miles, one new with sticker on it for spare on proper spare rim.
Maintenance and upgrades done within 6000 miles:
Two oil changes with new filter (WIX) and Valvoline 10w30
Coolant flush, eliminate rear heater due to leak, can be repaired, no parts removed except rubber heater hose.
New thermostat and gasket and seal
New alternator
Rear brakes cleaned and adjusted, shoes above 50%
New Optima Yellow Top Battery
New stainless steel battery tray with stainless battery hold down.
New bearings and seals in rear differential when locker was installed.
New Distributor cap, rotor, spark plug wires and spark plugs. All OE quality, no cheap stuff.
Transfer case serviced
Transmission serviced
New wiper blades front and rear
Both differentials serviced, removed and inspected front. Filled with 75w150 Venom full synthetic gear oil
Replaced both lockouts with Aisin good used units from Toyota mini truck
Spare tire removed from underneath, rear sway bar removed
CB installed on back of center console, whip antenna on front bumper.
Scion CD player installed in factory position,
New windshield
Cleaned IAC
New fuel filter, air filter and PCV valve
New fuel sending unit
New Radiator
Good stuff: Runs and drives great, wheels great and is in very good mechanical condition.
The bad parts: This truck is 18 years old. I purchased this truck from the original owner in Aurora Illinois in December 2006. It has a Midwestern body and therefore some rust. All panels and the floor are solid NO HOLES in rockers or floors. The body is restorable if you so desire. I do not. I have been wheeling it since the 2nd weekend I owned it. It was a doctor’s family truckster before I bought it and had never seen dirt. It has earned some battle wounds and dents. The driver’s rear power window does not have a good regulator, the gate power lock does not lock with the power switch but if you reach in from the back seat it will lock manually. The door key does not fit in the rear gate. The a/c is gone. The engine leaks a little oil, A LITTLE, less than 1/8 qt between services. The headliner has some stains from the previous owner. The bezel around the radio has a crack. The carpet isn’t show quality but it cleans up ok.
Accessories available to be sold with the cruiser but not included in the price above:
Warn 9500TI winch, 2.5 years old works great $850
BDS 3” suspension lift, all four springs, box kit with ubolts, bushings, etc. All four shocks also included with lift $650
Rear class III trailer hitch $140 NOW INCLUDED
One pair of new in the box anti reversal shackles $35
Two pair of new in the box early production Monkey Parts designs shackles $50
More as I remember it.
NOW DONE! ALL installed in last 2000 miles.
Front axle birf rebuild
New front wheel bearings and seals
The truck is in Oshkosh, WI and can be viewed by appointment. PM me or email dan at lenz auto dot com no spaces. I can ship the truck at my cost to most anywhere as long as we agree on a price. Buyer will pay for shipping. The company I work for transports as well as buys transportation all over the 50 states, Mexico and Canada. Thank you and have a great day.
PM returned. Pics later today.
Attempt at pics
wow
Pictures are two days after a weekend excursion to the Dunes. 214 miles and 8 hours on a ferry, no problems at all. Two solid days of wheeling. This weekend it will get serviced again, vacuumed and etc.
Open to offers. Thanks
Let's make this thing move.
New price and lots more maintenance done.
New radiator installed, front birfs rebuilt, new wheel bearings and seals done, class three hitch installed.
Winch is on the truck but not included. Lift is NOT installed but can be sold with the truck for the price listed above.
Thanks 'mud.
Just the truck as is, no winch, no sliders, no extra parts $2800 or trade?
