Parting Out 1989 FJ62 in WA
Crossing my fingers on this stuff.
I am in need of some sensors off of your thermostat housing. Honestly it would probably easier to just get both of the upper and lower housings from you to avoid breaking the sensors upon removal. Need the cold start timer switch (182-66) and water temperature sensor (182-65) from the picture on Specter.
I also need the connector and a bit of wire to repair my broken harness at the Water Temperature Switch, if you are willing to cut your harness. P/N 182-67 on the picture on Specter.
I would also like the fusible link mounted near your battery. It has three wires coming from the positive terminal headed into the arenas with two rather large quick disconnect connectors on each end.
I
I will look for it tomorrow, I never sold that part.
the 182-67 is there but i need to see photos of the plug in the harness + photos of the fusible link. 182-65, 182-66 are broken, sorry.
Thanks for checking on those sensors, they seem to be vulnerable to damage. Here is a link to the pic of the fusable link. I would send a picture of my exact link for comparison, but it has been completely bypassed by some thrill seeker. Best i can tell, that harness shown will jive up with mine.
Air filter base only, do not need top.
