- Location
- United States
SOLD SOLD SOLD 1989 FJ62 Built - Oregon
PRICE $7000
(with permission, much of the following is re-printed from the prior owner)
Here is the bio
1989 FJ62 (champaign tan)
4th Owner with ALL receipts and records (think 4+ inches)
236k miles, all engine/transmission was done 8k ago for no real good reason other than having something to throw money at.
SF Bay California Car – brought to Oregon two years ago.
Body is straight, no dents, never been in major accident. The rear lift gate was dented so a good new ones was painted to match (inside and out – removed all HW).
Engine
Long Block rebuilt by Clark’s machine shop (Cupertino, CA)
NEW
ALL hoses
ALL hose clamps w/ new Toyota Hose clamps
Belts
Radiator
Water Pump and Fan Clutch
EGR Valve
EGR Vacuum Modulator
Motor Mounts (Toyota)
Oil Pan
ALL Gaskets (replacement Toyota)
Fusable Link
120 Amp Alternator
Starter
Plugs/Wires/Cap/Rotor/Fuel Filter
Oil Filter (6 extra too) large old Toyota OEM
FPR
SS Battery tray w/ clamp for “standard size” battery
SS Battery tray clamp for Optima Series 31 battery
PS Pump
AC dryer
FlowMaster 60 Series Muffler
Rebuilt/Reconditioned
All injectors cleaned and balanced by RC engineering
TPS from Cruiser Parts
EGR Gas Temp
ECU from another cruiser
VSV from another cruiser
Transmission
Rebuilt A440F and Torque Converter
New Rodney (Automatic Transmission) Valve Body
New Rodney AT Temp Gauge setup
New Transmission Cooler (Plate style)
Transfer Case
TC rebuild done with ALL NEW bearings from Toyota
Replaced the PTO gear setup with the one from Australia
Suspension/Steering/Wheels
NEW
Tie Rod/Drag Link
OME Shocks and Steering stabilizer
Terrain Tamer Springs (heavy)
Anti Inversion Shackles
Greasable Pins
Poly Bushings
Rear Sway bar extensions
New Sway bar bushings (Toyota)
15x8 Rock Crawlers
32x11.5 Bridgstone ATs (7k mi)
Steering Box from another cruiser (much tighter)
Front end rebuilt about 3k mi ago.
Brakes
New
FJ80 MC (non-abs)
91 4Runner Calipers and Pads
TSM Rear Brake Conversion – Eldo style with e-brake
SS Brake Lines
Good E-Brake Setup with all new cables
T-100 Soft lines from body to axel
Body
ARB Front Winch Bumper
Warn Fairlead (no idea why the owner put this on without a winch)
ARB Side steps
Kaymar Rear Bumper (w/ Swing Arms mounts but no swing arm)
Tail Light Guards
Fender Flairs (Australian/Man-A-Fre) Style
Safari Snorkel – not installed
Interior
JVC receiver (MP3 plus exterior mini-jack plug)
Front & Rear Speakers (Pioneer)
Rear diamond tread rubber mat
Weather Tech front mats
Nifty mounted fire extinguisher and MagLight
Dash has a small crack right above stereo.
Other
More spare parts than you know what to do with (all in a RubberMaid Action Packer)
A well used 1989 FSM (the good one)
A Chiltons manual good for starting a camp fire
A COMPLETE printout, sorted in a binder and in protective sleeves, of the parts microfiche
What is Wrong
Blows code 71. I think I have replaced “everything possible” – still think it is the VSV, but haven’t bought a new one. Every time I go through the FSM procedure I get stumped.
Alignment is good, but the steering wheel is a bit “off” due to steering box replacement
Gas mileage – I am getting about 16 mph on the highway, but it is hard to pin it down exactly without a GPS due to the larger tires.
There was a small (and I mean small – size of eraser head) rust spot in the passenger side rear window. I had a pro body shop remove all traces and touch up.
AC – I have a new drier, but there isn’t ANY Freon in the system. You will need to get it recharged.
Paint – Clear coat is fading on the rear driver side. Some scratches in the roof.
What it Needs
Long Rang Gas Tank
Rear tire carrier
WINCH
Lights on the ARB bull bar
Roof Rack
CB
I love this truck, but my day job is now requiring more traveling to Southern Oregon (about a 500 mile roundtrip) and I need a commuter. I have never wheeled it, nor had the prior owner.
Truck is in Salem, Oregon - I can get away to show it anytime.
Shoot me an email and I will get right back to you with my phone number.
Thanks,
Mike
michael_r_rice@hotmail.com
PRICE $7000
Here is the bio
Engine
NEW
ALL hoses
Belts
Radiator
EGR Valve
Oil Pan
Fusable Link
120 Amp Alternator
Starter
FPR
PS Pump
AC dryer
EGR Gas Temp
Transmission
Transfer Case
NEW
Tie Rod/Drag Link
Greasable Pins
Poly Bushings
15x8 Rock Crawlers
Brakes
New
FJ80 MC (non-abs)
SS Brake Lines
Body
ARB Side steps
Tail Light Guards
Interior
Other
What is Wrong
What it Needs
Long Rang Gas Tank
Rear tire carrier
WINCH
Roof Rack
CB
Thanks,
Mike
