- Location
- United States
1989 FJ-62 Pristine Arizona Truck - Fully Restored and Built Up
http://www.sonoransteel.com/cruiser.html
1989 Toyota Land Cruiser FJ-62: Currently 218,000 Miles
For Sale: $20,000
E-Mail: steve@sonoransteel.com
This truck has been in Phoenix, Arizona since brand new. There is no rust on this vehicle what so ever. Frame is as clean as it was the day it came off the boat and the body is all original and not a speck of rust.
This is a close as you can get to going back to 1989 and buying one new.
I am putting the vehicle up for sale as it is my wife’s truck. She is not a wheeler and would now like a car or unibody SUV. It would have been nice if she liked wheeling but she does not. If it does not sell for the asking price, we’ll keep it. I have no pressure to sell it and do not mind keeping it for a long time to come. It’s only going to get more valuable.
Also no bank will give you a conventional auto lone for this much money on a 1989 vehicle. The buy is basically going to need to already have the cash. Please don’t e-mail if you would have to get a loan, they will not give you this much for a 1989.
Dealer Options:
Air Conditioner
Power Package, power windows, power door locks and power mirrors
Aftermarket Options:
ARB RD08 Air Locker (Rear)
ARB RD02 Air Locker (Front)
ARB Air Compressor
Quick Release Air Coupler and Tire Filling Equipment
Precision Gear 4.88 Ring & Pinion (Front)
Precision Gear 4.88 Ring & Pinion (Rear)
Precision Gear Master Install Kits (Two)
All Pro Chromoly Front Axles – Long & Short Sides
All Pro Profields (Two)
Cool Cruisers Complete Front Axle Rebuild Kit
FJ60.COM Front & Rear Brake Lines – Braided Stainless
New Front Knuckle Brake Lines (Two)
Old Man Emu Leafs Springs (Four, OME110 & OME113)
Old Man Emu Greasable Center Pins (Four)
Old Man Emu Greasable Shackles (Four)
Old Man Emu Poly Bushings (Complete Set)
Old Man Emu Front Steering Stabilizer
Old Man Emu U-Bolts (Complete Set)
Daystar Poly Bump Stops (Four)
LSPV Valve Lift Block
Custom Front Bumper: Made by Randy Ellis Design
Custom Rear Bumper with Trailer Hitch: Made by Randy Ellis Design
Stubbs Welding Deluxe Rock Sliders Welded On (Both Catalytic Converters Retained)
Draw Tite Modulite Heavy Duty Electrical Trailer Harness
American Eagle 55 Aluminum Wheels 8x15 (Five)
Yokohama Geolander AT Tires 33x12.5x15 (Four)
Stock Toyota FJ60/62 Chrome Wheel 6x15 (Spare)
B.F. Goodrich All Terrain Tire 33x9.5.15 (Spare)
Disc Brakes Australia Slotted Rotors (Two Front)
Disc Brakes Australia Brake Pads (Two Front)
Man-A-Fre Rebuilt Steering Box
Man-A-Fre 4 Piece Tie Rod Kit (All “Triple 5” Made in Japan)
Cobra 75WX ST CB Radio
Big Mouth CB Speaker
Wilson 1000 CB Antenna – Roof Mount, Removable
Panasonic MXE CQ-DFX883 Stereo – CD, MP3, AM, FM, Sirius
Polk EX365 6.5” Speakers (Four)
Toyota Factory Service Manual 1989 Land Cruiser
Windows Tinted: 20% front & 35% rear
Front & Rear Seats Completely Reupholstered
Custom Made Parking Brake Boot Matches Seats
Cool Cruisers Carpet Kit, Aussie, Molded, 4 Piece
Cool Cruisers Carpet Molded Wheel Arches, Aussie, 2 piece
Dash Designs Dash Board Cover
SOR Floor Mats (Four)
SOR Cargo Mat
New Genuine Toyota Sun visors (Both Sides, Discontinued Item at Toyota)
Passenger side A-Pillar Handle
Cargear Leather Steering Wheel Cover
JT Outfitters Rear Disc Brackets (Not installed but included with truck)
Custom Exhaust End Out The Side
Maintenance & Upkeep
(Everything within the last 2.5 years or less, around 25K miles of use)
New Hood Liner & Clips
New Washer Bottle Cap
New Hitch Receiver Cover
New Hood Bumpers On Front Fenders
New Hood Rod Bushing
New 4WD Shift Boot
New Seat Belt Covers
New Ash Tray
New Rear View Mirror
New Steering Wheel Cover
New Rear Tool Panel
New Auto Transmission Shifter Cover
All New Dash Board Bulbs
New Done Light Cover
New Tail Light Lens (One)
New Side Marker Lights (Two)
New Halogen Headlights (Four)
New Backup Light Switch
New Sears Diehard Battery
New Neutral Safety Switch
New Fan Clutch
New AC Evaporator
New AC Radiator
New Air Intake Hose
New Genuine Toyota Radiator
New Front Calipers
New Rear Brake Cylinders
New Rear Brake Shoes
New Genuine Toyota Wipers Arms & Blades (Front & Rear)
New Genuine Toyota Rear Window Struts
Full Transmission Flush and Service
Six Brand New Genuine Toyota Fuel Injectors
Six Original Fuel Injectors – Cleaned and Serviced by C&C Fuel Injection
Re-Manufactured Brake Booster
Complete set of Brand New Toyota Belts
All Brand New Transfer Case Seals
Two Brand New Oxygen Sensors
New 4WD T-Case Switch
Motor Top End Rebuild @ 199651 Miles:
All Hoses Replaced (Everything in the entire engine bay)
Fuel Dampener Set
Engine Gasket Kit
Water Pump
EX Valves
Lifter Gasket
Spark Plugs
D PNER Set
Distributor
Rotor Assembly
O Ring Kit
PS Gasket Kit
Water Temp Sensor
Complete Cylinder Head Overhaul, Machine, Valves, Sets, Everything New
Thermostat
Lower end was in perfect condition, cylinder cross hatching still intact.
Off-Road History:
This is my wife’s truck. I thought she might like wheeling, but like most women, she does not. This vehicle has seen very little trail use. Here is its entire history, in order:
For Sale: $20,000
Dealer Options:
Air Conditioner
ARB Air Compressor
SOR Cargo Mat
New 4WD Shift Boot
New Ash Tray
New Rear Tool Panel
New Fan Clutch
New AC Evaporator
New AC Radiator
New Air Intake Hose
New Front Calipers
Fuel Dampener Set
Engine Gasket Kit
Water Pump
EX Valves
Lifter Gasket
Spark Plugs
D PNER Set
Distributor
Rotor Assembly
O Ring Kit
PS Gasket Kit
Water Temp Sensor
Thermostat
Off-Road History:
- Lake Pleasant to Crown King (Arizona 3/5, easy run)
- Coke Ovens (Arizona 2.5/5, easy run)
- Tip Top Loop (Arizona 3/5, easy run)
- Hells Revenge (Moab, 3/5, easy run)
- Golden Crack (Moab, 3/5, easy run)
- Sunflower Mine (Arizona 3/5, easy run)
