- Location
- United States
sold for $4500
Hey Fellas! My co worker and long time best friend, Brent, is selling a real sharp Runner. So this is his ad copied from another forum. Its being stored at my shop here in Newberg. Its a very nice truck!
-4 cylinder 22re
-5 speed transmission
-immaculate inside and out.
-clear title
-219k miles on it
-new timing chain with steel guide
-new water pump
-new brake pads
-new brake callipers
-turned rotors
-new upper and lower ball joints both driver and passenger sides
-packed wheel bearings
-alignment was done after replacing the ball joints
-new valve cover gasket
-has A/C and it works
-15 inch aluminum alloy wheels.
-31 inch firestone wilderness all terrain tires with about 50 percent tread.
-new windshield
-new fuel filter
-new oil pan gasket
-new oil pump seal
-new front crank seal
-oil and filter were changed when replacing the timing chain
-front diff, rear diff, transmission, transfer case oils are full and the fluid is clear
-runs and drives really good
-NO RUST!!!!!!
-needs back trim pieces that cover the bolts that hold down the removable top inside(gray). but trying to locate the pieces.
-has a few dings and scratches due from age of vehicle
-ON A SCALE OF 1-10 I WOULD RATE THIS A SOLID 8
-ALL THIS VEHICLE NEEDS IS A NEW OWNER!!!!!
CONTACT BRENT 503 537 7224 IF I DONT ANSWER LEAVE A MESSAGE WITH YOUR NAME AND NUMBER FOR ANY FURTHER QUESTIONS OR IF INTERESTED. i can also send more pictures through e-mail. ASKING $4,500 CALL IF YOU WANT TO SEE IT. WILL MEET SOMEWHERE IN BETWEEN
-4 cylinder 22re
-clear title
-219k miles on it
-new water pump
-new brake pads
-turned rotors
-new windshield
-new fuel filter
-new oil pan gasket
-new oil pump seal
-NO RUST!!!!!!
