For Sale 1987 Toyota Pickup 4x4
1987 Toyota Pickup 4x4...Southeast
SOLD!!!
This is my brothers truck. Price $5000 OBO, Location Calhoun, GA. 30701 Odo shows 238K but who knows, it was swapped in when the other one broke.
Power Train
* REBUILT22r converted from RE
* Tightest 22r I have ever seen, no valve train noise. Motor is AMAZING.
* Turbo Diesel Plastic Tank Radiator
* Headman Headers
* 2.25" exhaust all the way out
* REBUILT Transmission
* Factory 4:10 Gears
* Stock Transfer Case
* Cv's are in good shape
* No leaks at all
* Upper Ball Joint Spacers
* Worn Tie Rod Ends Replaced
* Rear Add a Leaf
* Pro Comp 9000 Shocks
* Optima Yellow Top
Exterior
* Fresh PPG Single Stage Paint, slight orange peal (Purposely for thick coat)
* 33 x 10.5 BFG KM2's 80+% (See Pic)
* Fresh Sprayed in Bedliner
* New 15" x 8" Steel Wheels
* Fresh Undercoat (Zero Frame/Body Rust)
* Light Bar (Lights Work)
* Custom Rear Bumper (All 1/4" Material)
Inside
* Mazda Bucket Seats
* 6x9 Door Speakers
* Dash is cracked pretty bad
* Door Panels in good shape
* CD Player
* No AC or compressor
This is a solid truck. The carb does need adjusting to eliminate the puffs of black smoke at start and acceleration (Probably Jets). Still runs strong with the factory gears and 33's. I would prefer you contact him via phone but I may be able to help out a little on here.
Jarrod 770-608-8806
A little Saturday Bump...check out the changes in the Powertrain section, I forgot the motor was rebuilt.
I have seen this truck in action and its impressive. It went through a mudhole in 2wd that my 96 FZJ80 spent an hour in before getting a tractor to pull it out. Yes the 80 has lockers. And just to rub it in he stopped in the hole and still made it.
Don't miss an opportunity on this truck!!
