1987 Land Cruiser FJ60 For Sale. Original Owner
1987 Land Cruiser FJ60 For Sale. Original Owner. Putnam County, NY.
For Sale is my 1987 Toyota Land Cruiser FJ60 which I bought new. I had many incredible experiences with this vehicle which has been carefully maintained. It now has 184,000 miles. I used it as a daily driver and for camping until I bought a new daily driver a few years ago.
I have all maintenance and other records, manuals, service records, and receipts.
I have many parts available also.
Located in Putnam County, New York.
chrisr.interport@rcn.com
$2500 or Best Offer.
Has been run only on synthetic oil since very early on. It has an Optima (blue) battery.
Front left (driver's side) fender is a bit crunched from stupid accident on my own property where brake wasn't set and it rolled slowly on its own into a tree. Has rust in usual areas around rear wheel wells, etc.
Some of the Service I've done in the last few years:
Replaced all Tie Rods and Tie Rod Ends
Replaced Relay Rods and Relay Rod Ends.
Replaced Front Inner Axle Seals.
Replaced Front Spindle Gaskets, Backing Plate Gaskets, Front Wheel Seals, and Hub Gaskets.
Replaced Front Rotors and Calipers.
Replaced Air Injection Manifold.
Replaced Charcoal Canister.
Replaced Radiator.
Replaced Fan Clutch.
Replaced fuel pump.
Carburetor serviced and rebuilt by TLC Performance.
Replaced Clutch Master Cylinder.
Replaced Fuel Sender.
Replaced AC Compressor, Clutch Assembly.
Replaced Catalytic Converter.
Modifications I've added:
-Factory Hand throttle.
-Warn 8000 lb. Winch and Grill Guard. Winch has not been used in a long time. Grill guard has been removed, however the Winch Mounting Plate and Bumper Extensions that were custom made and installed took a lot of work and is a fantastic winch mount.
-U-bolt skid plates.
-Passenger Grab bar.
-High output 140amp Wrangler alternator.
-Add-a-leaf Suspension Springs.
-Heavy duty Bilstein shocks.
-Reverse light momentary switch.
-Left hand battery tray.
-H4 55/100 Headlights.
-SSB-CB slide mount.
-Stereo Amplifier (60W x 2).
-Stereo Amplifier (75W x 2).
-Stereo receiver.
-Speakers. 2-6.5" in front, 2-6x9’s in rear hatch.
-Electric Antenna with factory switch.
-Radar detector hard wired.
Will sell at additional amount:
Assorted parts,
Custom grill guard. (from Land Rover).
1/5 Horsepower 12V Air compressor installed under the hood.
Rear Storage box.
Full set of Micro Fiche.
Fiche reader.
Trailer Hitch for FJ60.
Factory Tools.
Yakima Roof Rack.
Problems:
--Steering Hose Leak.
--Water Pump may need replacing.
