1986 FJ60
Year
1986
  1. 60 Series
Mileage
178500
Color
Gray
1986 Toyota Land Cruiser FJ60
Details:
178,000 Miles
Clean Title
4 Speed Manual
Lift Kit
New Bridgestone Dueler Tires (31”)
Recent clear smog check
Recent work done:
  • Brand new grill
  • Headlight bezels and turn signals
  • New radiator
  • Front axle rebuild
  • New front brake calipers, rotors, lines, pads
  • Install of rebuilt brake booster and new brake master cylinder assembly
  • Transfer case overhaul (transmission was also removed at this time and inspected and found to be in great shape)
  • A/C overhaul with every component replaced
  • New front and rear seat upholstery and foam, all new interior carpet/padding with Kilmat installed over the tub, doors, and side panels (as well as the hood underside) and does a fantastic job of sound and heat mitigation
  • Any surface rust on the frame was sandblasted/wirewheeled and treated with converter then a thin coat of satin enamel applied
  • New exhaust cat-back
  • OEM dash cap about to be installed
All components used in replacement/overhaul were either factory OEM or high quality MIJ third party components ordered from FJ enthusiast sources.
If you’re looking for a solid FJ look no further. All the big things have been done. Shows beautifully in person besides a few small rust bubbles in the normal area behind the rear wheel fender. Drip rails are perfect. Asking $30,0
00.
Call or text Mike at 949-525-0717
