- Location
- United States
1986 Toyota FJ60 196xxx miles. For sale. I am looking to get $5500.00 obo.
It runs like a top. Doesn’t smoke jus like the owner.
The following is a list of items recently replaced or repaired:
Lift kit, new bushings, greaseable shackle pins, ubolts, springs
Clutch, Machined the flywheel, New clutch fork boot, throwout bearing, pilot bearing, rear main seal
New oil pan gasket
Tune up including: plugs, wires, cap, rotor, air filter, fuel filter.
New tail pipe, cutout muffler and had new tailpipe welded in after the cat
Repaired tubing to rear wiper fluid sprayer outlet
Bought second hand set of black steelies with 33 1050 15 BFG MTs. no spare
After I put the 33” tires on the speedo was off so I took it down and had a speedo corrector made.
NOTE: also after bigger tire installed the rig is still ale to clear the garage door
Put an additional outlet in center console for accessories.
I have receipts for all of the above items.
The other things that are working are the rear heater, front heater , A/C blows cold.
All of The glass has no cracks and is in working order, rear defroster is working.
Brakes are in good repair I inspected during lift process.
Any thing that should work is in working order on the truck except for the head light washers. The motor works and sprays fluid, like a champ, but the reservoir is cracked and doesn’t hold fluid. Tried to repair, worked for a week but failed.
Has hitch and trailer light wiring.
Also has CD player w/ remote, and cable to plug mp3 player in and XM satellite radio.
Also if interested I also have a ski rack for it
O.K. now for the ugly.
Body is in great condition except for three spots: Front left fender aft of the wheel well has rust, left rear quarter panel has rust aft of the wheel well and under the right front headlight on the valance.
I had to remove the carpet during the replacement of the clutch and while out I inspected the floors and rocker panels. I even removed the rear carpet, the body is SOLID.
The front left and rear right bumper caps are gone.
No major tears in seats, just the drivers side is cracked on the side. The rear cargo area carpet is torn but presentable.
Also dashpad is cracked in 2 spots.
If interested contact me at buynsellcos@yahoo.com
I have nothing to hide so feel free to ask me anything you want about the FJ.
Meticulous
New oil pan gasket
Meticulous
