- Location
- United States
This is an excellent running truck with the original 2F motor. The truck has a little over 164,000 miles on it. The following is a list of equipment or modifications that have been done.
4.88 Gears
Lock-Rite Lockers Front & Rear
Spring Over Axle (Front Axle cut and turned)
Transfer Case Rebuilt (8/09)
Centerforce Dual Friction Clutch (8/09)
DUI Ignition
Milemarker 8000lb winch
ARB Bull Bar
ARB Safari Snorkel (Mounted needs to be finished under the hood)
ARB Roof Rack
OMF Beadlock Rims (Set of 5) These are for sale seperately for $2000.00
2 1/2 inch OME lift springs
2 inch Downey lift shackles
ARB Fender Flares
Optima Yellow Top Battery (1 Included)
Rear disc brake conversion (Cadillac Eldorado Calipers with built in parking brake) fabrication needed to link up to stock parking brake.
Mean Green 200Amp Alternator
Profields (Similar to Longfeild)
FJ80 non anti-lock brake resevoir (Needed for rear disc conversion so no proportioning valve required).
Things included but not installed
2F Header (Truck needs exhaust from the CAT back)
2nd Stainless Battery Tray for Dual Battery Setup
1986 Toyota Landcruiser <- Craigslist Add
The body has rust in the normal areas. This is an excellent trail vehicle and ready to go I will provide more pictures if requested. E-mail me at Funkymm0011@aol.com
4.88 Gears
DUI Ignition
ARB Bull Bar
ARB Roof Rack
ARB Fender Flares
