For Sale 1985 toyota ext cab rock crawler
Decided i want the room and someone should enjoy this, it needs a little attention as it has been sitting since i built a buggy. 1985 toyota 22re dual t-case with second case 4.7 gears and practicaly new 40" LTBs. This has been of the most capable rigs in the state on 40"s. below is the part list...almost $9k in parts
Asking $5800
call 616-886-1869
Turbo clutch
Marlin dual t-case set up
Marlin 4.7 tcase gear
Long Field rear T-case out put shaft
Custom low profile t-case mount
Longfield fron axles shafts
Longfield hub gears
High Pinion front
ARB front locker
Air tank for ARB
Marlin crawler 25mm pin upgrade
Marlin high steer arms
Custom cross over steering w
custom 1.5 DOM 1/4 wall tie bar
w/heim joints
Hydro assist
Hydro resevore
IFS Steering box
Custom axle truss w/ball supports
Knuckle stud kit from Marlin
Custom front diff guard
FJ60 rotors
IFS calipers
IFS hubs
U bolt flip kit
inner air lock dual bead locks
LTB swampers 40x16x15
alum rims 12x15
Front custom spring hanger
Front allpro 6" springs
rear 63" springs
rear flip shackle
rear axle hing spring mount
4-5125 Bilistein 14' shocks
dual battery w/ switch and mounts
stinger
exo cage
Custom front & rear square driveshafts
Spare custom driveshafts
SPARE PARTS BELOW ARE AVAILBE FOR EXTRA $$
rear ring & pinion
steering box
transfercase
Transmission
front axle shafts
rear axle shafts
brake calipers
front IFS and Solid axles bearing hubs
Front lock outs
