- Location
- United States
Hey guys another canadian here have my wheeler of 8 yrs here and im looking to get into a cruiser now so im either gonna sell it or trade straight across for the right rig.. lemme know if you got something!!! Located in BC Canada
1985 K5 Blazer
New Rust free tub and front clip with electric tailgate with tinted glass, Lund Visor, Body is undercoated, H4 Conversion Lenses for HID’s (bulb 9004 style)
Fiberglass Half Top and Dessert Camo Soft Top
(500hp) 454 Big Block Chevy brand Newly Rebuilt, Flat Top Pistons, Comp Cam Roller Rockers, Edelbrock RPM Air Gap Intake, Holley 750 Double Pumper Carb, Comp Cam 278 Dur, Mallory 85 Series Alum Distributor, Headers, MSD Spark Plug Wires, Holley Black Series Electric Fuel Pump, Edelbrock Adj Fuel Pressure Regulator, Full Aluminum 4 Core Race radiator, Dual electric Fans, Dual Battery Isolater, VTwin On Board Air Compressor with Tank puts out 11.5cfm at 100psi.
3” stainless steel body lift, 8” BDS Suspension lift (8” front springs, 8” rear springs, Skyjacker extended front and rear brake lines stailess steel rubber coated) 11” Total Lift
42x15x15 Super Swamper TSL’s on 15x10 steel 8 bolt wheels with Brand new 40x15x15 Swamper on 8bolt wheel for trail spare
Front Dana 60 Kingpin: 1350 Yoke, Rockcrusher Hardened Diff Cover, 35 spline inners and 35 spline outer stubs (Moser Engineering), 35 spline warn prem hubs, brand new SRW hubs with new wheel bearings , dust seals, Rotors, and Brake pads, 4.10 Open Carrier/gears, Ballistic Fab Hi steer arms, Rebuilt LF upper and lower kingpins and new Drivers side knuckle, PSC hydro assist ram 8x1.5 , Brand New Moog TRE’s on tie rod and drag link.
14 bolt FF Rear: Loc Rite Locker, 4:10 gears, disc brake conversion( DIY4X) with ebrake calipers from Cadillac Eldorado, New Rotors and Pads.
Custom Made aluminum Fuel Cell 43 Gal 162 Litre Capactiy with Autometer Fuel Level Sending Unit.
Bowtie Overdrives Stage 2 K case transmission with Shift Kit, built up clutch packs, updated servo, better planetaries, 2400 staill B&M Torque Converter, and Advanced Adapters th350 short tailshaft upgrade to adapt to NP205 Tcase, B&M Unimatic Floor Shifter.
Np205 Tcase: Fixed yoke rear, front yoke 1310, Advanced Adapters Th350/700R4 Np205 Tcase Adapter (solid Aluminum), Energy Suspension Adapter Bushings Poly Urethane, New Front Driveshaft lengthened and double carden rebuilt with spicer joints.
63” Hi Lift Jack Brand New with Hi Lift Jack Mate adapter, 50ft 55,000lb Tow Strap with clevis x2, Shovel
WARN winch bumper with Fairlead ready to accept a winch.
3 gauge pod with autometer fuel, transmission temp, and Tach gauges inside pods. Cobra 19DX CB radio with PA Speaker Mounted in Engine Bay Dual CB Whips 4’, 1999 Jeep YJ Bucket Seats.
2wd Power Steering Box modded with DIY4X rear cap and fitting, drilled and tapped upper cap with fitting, 4” Drop Pitman arm
$$8500.00
LOcated in kelowna BC Canada
250 863-2742
Nick or feel free to e-mail me ddr_bot@hotmail.com
1985 K5 Blazer
$$8500.00
250 863-2742
