For Sale 1985 FJ60 - Colorado
Year
1985
  1. 60 Series
Not mine and I usually don't post here, but looks good $21,000
This is a 1985 Toyota LandCruiser FJ60 that I have loved and babied with no plans to sell, however...
I have all receipts showing the following work completed here in Colorado in 2006 by johns 4x4 in Boulder
Brand new not rebuilt original Toyota 2F engine installed
New clutch assembly
All new heater hoses
New Motor Mounts
Resurfaced Flywheel
Replaced front brakes including all hardware and calipers and rotors
Sway bar end links
2 1/2 " OME lift with all new springs and shocks \
New warn hubs
Air Injection manifold assembly
any many smaller items totaling $15,000 in 2006
This was at 211,000 miles -
It runs excellent and has no problem going anywhere - I would trust it to make it across the USA - I drove it out to Moab for a Mountain Biking trip about 6 weeks ago - No problems at all
Goes in and out of 4x4 with no issues and shifts smooth through all gears
It will run down the road at 65 MPH with no issues at all
I have replaced the alternator
New Carpet set
New Hand stitched seat covers made in South Africa by Equipt
Dual batteries - I had this hooked up with a Fridge on the 2nd battery
Tinted windows
4 great FJ40 steel wheels with newer 33x10.5 MT tires
All fluids are fresh within the last 4 months
Upgraded headlights to HID - What a difference
The truck had rust behind the rear tires and this was cut out and welded in and new panels installed
Just repainted in its original color Dune Biege
Chasis is rust-free
Most everything works like it should except the horn
Ac and heat blows hot and cold - I had this converted to the RG34 coolant about two years ago
This has been de-smogged and runs with a weber carb
It leaks some oil
other than that it is an amazing truck and turns heads everywhere
Its not a show truck but looks amazing
and needs a couple of trim pieces here and there -
If your looking for a beautiful FJ60 that could be a daily driver this is it
Rack not included
more pics
Nice fj60! awesome documentation. Good luck with sale.
