- Location
- United States
SHUT... Closing this ad down if that's possible. I will repost if I get time to go through the remainder.. Thanks.
1) Brown Carpet- complete with some fading/fuzzy strands minor stains and has been cleaned except tailgate panel (included) SOLD
2)Heater core new with the last year or two, Vista Pro (?) automotive $50
3)Rear heater- a little corrosion inside, likely spilled beverages, knob still on switch $50
4)A/C compressor, turns over fine, compressing with barely noticeable pulley wobble $25- still for sale
5)A/C box with all attached wires $40
6)Smog Pump- Looks like an aftermarket modified to work in a fj60 $25
7)Driver's side front window regulator- really silver, no rust, must be a recent OEM replacement- $50-SOLD
8)Driver's rear " " " , looks fine, $25
9)Passenger's side front window regulator- $40
10)Passengers " rear " " - $25
11) Chrome "TOYOTA" bezel off of rear drop down tailgate one minor ding in chrome, light surface rust on underside, rubber looks great $60. SOLD
12)Power Steering Box- there are different patterns for different years btw. This one turns smoothly.. I will ship but sold as is where is. No signs of leaking or issues. If it is bad I will refund purchase price but buyer will be responsible for shipping costs $150
13)Steering wheel/Column/Cover/Ignition cylinder. Wheel has some scuffs from wreck and is crooked and lever on lever (lights) is broken.. $75 Cover sold
14)Washer tank w/fj62 or fj60 pump. Lid and tank are good, all or whatever, $45 sold
15)Voltage regulator from reman alternator $20
16)Heater blower (newish) universal brand $25-SALE PENDING
17)Passenger side-marker/turn signal lense and broken housing, not faded (missing one screw) $15
18)Red passenger rear marker in good condition, gasket for DS, and the two taiwan rubber front housings and one faded front org. markers missing screws $10
19)Vacuum booster and master cylinder $150
20)Ebrake assembly (let me know if you need parts off of frame $25 sold
21)Speedometer cable $15
22) Gauge cluster- don't make me split this up, $60
23)"OPEN" vents $20 for the pair
24) Front door hinges all four $20
25)Battery tray, hook and hold down, some rust and peeling rubber coating but solid, tweak on hold down $20
26) Dizzy- some corrosion on inside, inside vac advance diaphragm leaks $40 SOLD
27) Coil w/igniter $40 SOLD
**** sidecover and hoses from block would allow this to be used on earlier models..
28)Starter (reman from Napa) gear reduction type $50
29)Glove box door with a little dent $5
30)Console lid some stain (?) SOLD
31) Choke knob with set screw!!!! $10 (shipped) SOLD
32) Wiper motor $30
**ENGINE**
Recently rebuilt but block is cracked at PS motor mount, the cross hatch is still fresh, pistons are .050 which I believe means it was bored 50 1/1000's over stock, head looks really good, intake shot/ exhaust had butterfly welded (in the wrong position)- All will be parted out- let me know what you need.
More items will be added and prices with request. Sheet metal is good for patching panels- I have found some indication of body work as this was repainted but I have found no rust. NO SHEET METAL LEFT
. T-case is not available. Please PM with parts requests and I will update this top thread with parts and conditions. Items are located near Grants Pass, Oregon, about 25 minutes off of I-5. If you see something in the pics you want PM and make an offer while you are at it. If you view my other posts you will find pics of the rig.
32) Wiper motor $30
**ENGINE**
