1984 FJ60 Landcruiser For Sale
Now officially up for sale
Salt Lake City, UT
4200 OBO
Here's the skinny:
PO rebuilt the motor...I don't have any paperwork...but the compression was 165-175 across the board...and the block looks like it's been rebuilt.
PO rebuilt the tranny/t-case. There is a slight leak from the speedo-cable output on the t-case, but both feel really good(tight).
PO had the truck repainted and all the body rust fixed. I can only find small spots of body rust...most are pictured.
PO had the frame rails(and lower body) coated in some sort of "rhino lining type stuff".
Frame rust is minimal.
PO had the rear axle rebuilt.
I rebuilt the steer knuckles
I changed the front wheel bearings
I replaced the tie-rod ends
I replaced the steering damper(Rancho RS9000).
Truck has a fresh alignment
All fluids have been topped off(difs included)
Newer radiator
New Alternator pulley
New seal in PS pump...there is still a VERY small leak from the front side
Engine is fully smogged and passes emissions(at least it did three months ago)
I just had a rebuilt carb put on
I also did a valve job, but the valves are still a bit tight(there's a slight stumble at idle).
A/C works better than any of my other 3 cars
Has recaro copy bucket seats in the front...and will include a pair of corbeau buckets as well.
Replaced and routed(properly) all vacuum lines
New micron fuel filter
Had the fuel tank cleaned out
Replaced a couple of heater hoses
Just noticed the left birf is popping a bit...price reduced to reflect that
Sorry it took me so long to respond...I can totally post that(if you guys are serious...I can never tell on these forums:)).
Bump...make me an offer...I've got one person interested(promised him the first shot)...but if that falls through I'll entertain other offers
