Just for giggles, I asked AI to interpret the above schematic:
The schematic depicts the **electronic ignition system** used in Toyota Land Cruiser **FJ60/FJ62 series** (USA models) from approximately **1980 through 1987**, powered by the 2F engine (4.2L inline-6). This is a **non-points, electronic system** using a magnetic pickup (signal generator) in the distributor, an external **igniter** (ignition control module), and a coil to drive the spark plugs via the distributor.
It shows two representations:
- A pictorial layout (top part) with components and wiring connections.
- A more symbolic electrical schematic (bottom part) detailing current flow and grounds.
### Key Components and Their Roles
- **Battery** — Primary 12V power source, negative terminal grounded to chassis/engine.
- **Fusible Link** — A protective high-amperage fuse (wire) in the main power feed to the ignition circuit. Prevents catastrophic shorts from reaching the rest of the system.
- **Ignition Switch** — Controls power to the system. Provides switched +12V (only when key is in ON/RUN position) through the fusible link to the coil/igniter.
- **Ignition Coil & Igniter** — Usually mounted together (coil on top of igniter or very close).
- The igniter is the electronic brain: it receives a trigger signal from the distributor and switches the coil's primary circuit on/off to create high-voltage sparks.
- Coil has + (positive) and - (negative) terminals.
- **Distributor** — Contains a magnetic **signal generator** (pickup coil / reluctor) that generates an AC voltage signal as the engine rotates (no mechanical points).
- Distributes high voltage from the coil to each spark plug in firing order via cap, rotor, and plug wires.
- **Spark Plugs** — Receive high-voltage pulses to ignite the air-fuel mixture.
- **Tachometer Connection** — Tapped from the coil negative (-) terminal (often through a resistor or directly), providing RPM signal to the dash tachometer (and sometimes emission controls or AC amplifier in USA models).
### Power and Signal Flow (Tracing the Circuit)
1. **Power supply path**:
- Battery positive → Fusible link → Ignition switch (IG terminal when ON).
- Switched +12V feeds the **+ terminal** of the ignition coil (and powers the igniter internally).
2. **Trigger / control path**:
- The distributor's signal generator (pickup coil) sends a pulsing signal (variable reluctance / magnetic pickup) to the **igniter** via a 2-wire connector (typically shielded or twisted pair).
- The igniter processes this signal and internally switches (opens/closes) the ground side of the coil's primary winding.
3. **Coil operation**:
- When the igniter grounds the coil's - terminal → primary circuit completes → current builds in the coil's primary winding.
- When the igniter opens the ground → magnetic field collapses → high voltage induced in secondary winding (20,000–40,000V).
- High voltage exits coil tower → goes to distributor center terminal → rotor → cap terminals → spark plug wires → spark plugs.
4. **Grounds**:
- Igniter grounded to chassis/engine.
- Coil negative not directly grounded (controlled by igniter).
- Battery negative grounded.
5. **Tachometer**:
- Connected to coil negative terminal (often with a series resistor in USA models to protect electronics and reduce interference/noise on the signal line to the tach, ECU/emissions computer, or AC amplifier).
### USA-Specific Notes (FJ series)
- USA models (especially later 1980s) used this electronic setup with an external igniter/coil combo.
- The schematic highlights the **fusable link** and connector to the ignition switch side (plug/coupler shown).
- Some variations exist between early (e.g., 1980) and later (1987) models, but this covers the general 1980–1987 electronic system (replacing earlier points-style ignition).
- The small inset box (FJ 60 series) with IG, AM, etc., likely represents the ignition switch terminal labeling (IG = ignition).
### Common Troubleshooting Points from This Diagram
- No spark? Check fusible link continuity, ignition switch output, power at coil +, ground at igniter, signal from distributor pickup, and coil/igniter function.
- Tach not working? Check connection at coil - (and any inline resistor).
- Intermittent issues often trace to corroded connectors, bad grounds, failing igniter, or aged pickup coil in distributor.
This is Toyota's reliable early electronic ignition design — simple, durable, but the igniter and pickup coil are common failure points after 35+ years. If you're diagnosing a specific problem (no spark, weak spark, tach issues, etc.), provide more details for targeted advice!
