- Location
- United States
Alternator core of 310xxx kms. Vac pump is good. I checked the vanes, almost zero wear inside. Provided strong brakes until the regulator and diodes fried. Brushes look new.
Bearings are good, no play axial or radial.
Missing pulley, bearing spacer, and regulator.
Splines on the rear shaft looked fine when i pulled the vac pump off to check. It is reassembled without the pulley and bearing spacer.
Would be good for a rebuild or to rob the vac pump off of, honestly you could get a new rectifier and regulator and run it.
$75
$75
