1982 Toyota pickup
Sold
Located in San Francisco Bay Area, California
Rebuilt motor 22R, Low mileage. Runs well. Recent smog. Have not wheeled it much and drive on the road occasionally.
5 speed transmission.
4" lift springs I believe are all-pro. Bilstein Shocks up front. Rancho in the rear.
Dual transfer cases: Front is stock, rear has Marlin 4.7 gears. Inchworm dual case adapter. Marlin twin stick.
Long Travel Drive shaft up front.
Geared with 5.29 gears.
ARB air locker upfront.
Rear 3rd member is from a V6 axle housing and has a Detroit locker.
Rear Axle housing is from an IFS truck.
Rear axle shafts are Trail Gear.
Front axle shafts are 30 spline Longfields. Hubs have Longfield gear. Axle Housing is reinforced with Gussets
High steer.
Trail-Gear Six Shooter knuckles
Tires are Mickey Thompson 35"x12.5x15 MTZ Baja radials tires very low miles. I bought them new a 2 or 3 years ago.
Transfer case emergency brake from Sky's Off Road
4 wheel disc brakes. All Pro rear disc brakes.(these are the GM calipers)
Tube steel bed, sliders, front bumper with stinger.
Hi lift jack mount
Tool box
Warn m8000 winch
Cobra CB radio
Front wheel wells were sectioned and raised to clear tires
Had the Truck cab painted after I had a Cab swap done. 7 years ago when I first got it. Previous cab was banged up and was easier to swap.
I have photos documenting the swap, before and after.
May consider Possible partial Trade for stock, Tacoma Extended cab 4x4 with 3.4 and 5 speed.
Truck Located in the Bay Area, CA
Thanks,
Dave
Sold
High steer.
Hi lift jack mount
Tool box
Warn m8000 winch
Cobra CB radio
Thanks,
Dave
