- Location
- United States
1982 Toyota Trekker SR5 for sale in Harpers Ferry WV 25425 $3,000 cash takes it, these are almost impossible to find let alone in stock, unmolested non wheeled or beat shape like mine!
Ive decided to sell my Trekker, I need my garage bay back and need to recoup the funds for some house projects and it has to go. Its a 1981 SR5 Trekker, red with 180,000 miles, 5 speed gauges. The body is in good shape, no frame rust other than surface rust, it runs good, shifts good and the 4wheel drive is good and solid. It has all new cooling system / heater hoses, new belts, filters, under hood fuel lines, water pump, thermostat, radiator cap, the exhaust was replaced including the manifold a few thousand miles ago with the exception of the cat and it has new clutch hydraulics "master & slave cylinders". It also has brand new Yokahoma Geolander AT/S tires on refinished factory SR5 wheels. I had a locksmith make a new set of keys for the rear hatch.
The truck has a rust hole in the pass side front fender down low, not the metal behind it just the fender, it could be patched and the passenger side rear floor has a rust hole behind the seat. The frame is solid just has surface rust. For a 1981 its a definite candidate for a full restoration which is what I had in mind. The interior is all there including the back seat and rear arm rests! The truck was bought new by my friend Matts first cousin, which sold it to Matt back in 2000, Matts freind John bought it from him back in 2007 and I bought it last year so the history is well known on this one.... I have a valve cover gasket kit, if I get time Ill warm it up and check the valve clearances, if not it will go with it along with any other related parts I have for it, I have the spare tire / wheel but it has not been refinished. Ive put a few hundred miles on it and it runs good, there is some vibration coming out of the rear end but it does have 180,000 miles on it. Serious calls only please! ~Matt 304-671-1481
