- Joined
- Aug 18, 2002
- Threads
- 108
- Messages
- 1,569
- Location
- on the ice, wyoming
- Website
- www.pointyhatdesigns.com
- Location
- United States
Need some room in my garage, so I'm getting rid of some extras I hopefully won't need.
Front turn signals- you get all four, two of each side. The one the lens was cracked in half so I threw that away, and the turn signal lens is broken. Three are in good shape, other than small cracks in the lens on the corners where they screw in. Only two bases which are in ok shape, not great, and 3 bolts, but the one is probably not usable and the other two will take some work to get them to work.
Only one has a turn signal light, IIRC.
$40 plus shipping Turn signals are SOLD
Front heater- in decent shape, some of the foam is missing.
I filled it with water and the level didn't drop after a few hours.
$20 plus shipping
shipping will probably be $15-20 on this, depending on where you are because of it's weight. If you have a business address, slightly cheaper.
Radiator overflow bottle and bracket. Bracket is rusty, no cap on the bottle. Looks like it holds water.
$15 plus shipping.
Vacuum switch valve and purge canister. Out of my 76, part number on the VSV is 17650-61010
$15 plus shipping
$20 plus shipping
$15 plus shipping.
$15 plus shipping
