Ok so here we have the recent events, repairs, fixes over the winter.
- I had to replace the alternator as the old was just not enough for up coming mods. I cant remember the amps... might be 120A one wire.
- I replaced as well as installed some new ground cables.
- The dual battery tray was cut and welded so it doesn't take up as much room and now the batteries sit side by side. I also now have two NAPA 8434/78 batteries.
- I pulled apart the entire dash. I then traced down all wires that are no longer needed or being used. I cut them all out of the wire harness. I then cut out all unnecessary redundant wires like multiple grounds and power wires. Cleaned everything up and put it all back together. This went in conjunction to all other wires leading into the engine bay and forward. There is a ton more room and the electrical circuitry now performs as it should.
- I did a mass rattle can paint job on the pig. Also scraped off stickers that were falling off anyway. I cut the fuel can holder off the back tailgate bumper.
- Went to home depot up in Omak and bought some sound board and heavy rubber matting. Cut and lined the entire floor and firewall with the sounding board. That alone cut down on a ton of road noise. I then doubled it in some areas I was able to and laid the black rubber matting to make it look decent. I also lined the entire cargo area with the sound board and the cargo bay side panels. Also bought some piping covers and placed them over the shifter handles to help cut down on driveline vibrations. HUGE difference in noise reduction and it ran me well under 100 bucks.
- aligned some of the doors as best I could being they are beat up rather well.
- The transmission, transfercase, and overdrive gear boxes were low on lube. I toped them all off. Took over three quarts. I then bent the overdrive shifter handle because it was hitting the transmission shifting handle.
- The power steering pump is beginning to go out. So I am considering going over to an electrical power steering pump like those found on the 2nd generation Toyota MR2's. A bit spendy but I can mount it pretty much any place under the hood.
Cant think of much more... I know there are some other things I have done... will add them as I remember.
