craigslist 1972 Pig Alaska
Looks good from where I’m sitting. Might as well spend that crypto currency on something tangible!
From the listing:
1972 toyota fj cruiser
fuel: gas
title status: clean
transmission: manual
1972 FJ55 Toyota Land Cruiser - $4000 OBO. I also accept some cryptocurrencies such as BTC/ETH. I'll give you a $200 discount if you do!
Runs and drives. Replaced brake booster, slave cylinder, fuel pump, clutch, spark plugs & wires, battery cable, and thermostat. Original engine and upholstery. Manual four-speed (R and gears 1 through 3).
Brakes need to be bled, tie rods need replacement. Accelerator cable is a temporary fix and needs replaced. Speedometer and odometer does not work. Rear heater is disconnected. Electric rear window doesn't work. Front mechanical windows needs some TLC. New tires needed soon. Some rust on bodyshell. I'd recommend a realignment soon.
Runs and drives like a tank. Would be an ideal restoration project.
There was a nicer one with that paint scheme-my favorite- for sale up there earlier this year for about a thousand less. Really tough for me to resist the temptation too. Must remember that it would just rot away rapidly in the climate here.
