For Sale 1969 Pig & 1F parts
DTC72
Las Vegas
All parts are in Las Vegas. I have been meaning to catalog and post these parts for a while now. I can send pictures as needed but here is the list of what I have. Make an offer for individual or groups of parts.
1F Head 1969
1F rocker arm assembly 1969
1F valve cover 1969
1F side cover 1969
FJ55 inner door frame bulb seals #15004-25 new from Rock Auto = SOLD
FJ55 beltline tailgate/door flocked lining 1457-4x2 new from Rock Auto
1F alternator bracket and adjustment bracket = SOLD
1F Engine front mount brackets = SOLD
1F Engine rear mount brackets = SOLD
FJ55 starrier counter shaft
1F yellow 4-blade fan
FJ55 trailer hitch mount = SOLD
Heater ducts = SOLD
1F L-N-H pull handle/bar for vacuum assist transfer case, bracket for the four knobs
FJ55 original gauge cluster foam pad
1F coolant/water T
FJ55 tie rods
1F bell housing
1F bell housing under/inspection cover = SOLD
1F inspection plate dust shield = SOLD
Front Drum brakes
Rear Drum brakes
1F air cleaner mounting bracket
Rochester Carb
1F starter
1F oil pump
Front Heater Unit = SOLD
Rear Heater Unit = SOLD
2F head gasket
FJ60 air cleaner
Toyota 3point shoulder belts = SOLD
Old Toyota flip clasp seat belts
1 Toyota receiving piece seat belt
TK-810/820 seat belts = SOLD
Radio Antenna = SOLD
1F Distributor 19100-60062 Nippon Denso
Pic of 1F head parts
SOLD = 1F Bell Housing cover and dust shield
1F fan
SOLD=Front heater and passenger vent ducts
SOLD = Trailer hitch
Engine and Tran mounts = SOLD
starter counter shaft???
Miscellaneous stuff
1985 2F air cleaner
Interested in the alternator bracket and engine mounts
SOLD = Hard to see the bracket in the box but…
Also, can’t remember which are the engine brackets and which are the trans brackets? Shorter one vs longer one in original posting picture?
SOLD = Toyota 3point shoulder belts
Old Toyota flip clasp seat belts. These are what came in the early FJ55’s. Who needs a shoulder belt? Only wimps. Who needs a clasp that stays closed? Again wimps. Be a Land Cruiser stud and put these in your pig!
1 Toyota receiving piece only seat belt
1F Head 1969
1F valve cover 1969
1F side cover 1969
1F alternator & bracket
1F Engine mount brackets
1F transmission mount brackets
FJ55 steering box
1F passenger side air duct
1F L-N-H pull handle/bar for vacuum assist transfer case, bracket for the four knobs, defrost air duct/grate, old antenna
1F coolant/water T
FJ55 tie rods
1F bell housing
Front Drum brakes
Rear Drum brakes
Rochester Carb
1F starter
1F oil pump
Front Heater Unit
Rear Heater Unit
2F head gasket
FJ60 air cleaner
Interested in the seat belts
