For Sale 1966 FJ45 LV For Sale in Sacramento
Tega Cay, SC
Not mine. No relation.
HERE is the link to a post I saw in the classifieds.
HERE is the link to the CL ad, one of the pics and the text from the ad is below.
Engine
1962 corvette engine v8 256
New Hei distributor, wires, plugs,
Fuel system has been completely gone through. The gas tank was boiled out
and resealed. All hoses and fitting were replaced. New fuel pump and filter.
Carburetor was rebuilt, new water pump, new alternator, thermostat, hoses,
air filter, starter rebuilt, New battery and cables. Engine was rewired,
rebuilt radiator, All fluids replaced
Axles
Both axles have been swapped out with axles out of a 1972 cruiser. Fine
splined axles. The front axle has been converted to disc brakes. New brake
pads and calipers, brake rotors were turned, new seals and bearing.
Rear axle was gone through as well, new pads, wheel cylinders, seals. All
fluids replaced
Suspension
Add a leaf suspension kit. New shocks and u-bolts.
Hydraulics
New brake and clutch master cylinder. New slave cylinder, new brake lines.
Body
The outer body was sand blasted and primed a few years ago. The body was
not removed from the chassis so the under side still has surface rust. The
pictures show all the spot were the rust has eaten all the way through. The
front section of the vehicle is in very good shape but the rear half needs
some attention. There are a few spots where the rust is coming back so the
body will need more attention at some point. All of the lights function.
Interior
The Front seat has been newly reupholstered; some of the gauges don't
work. It originally shifted on the steering column but this has been
converted to the floor. It has no rear seat or headliner.
Misc.
The four wheel drive function as well as the pto winch. The winch is
lacking the hook on the end.
Areas needing attention
The Body is the main concern. The rear window hatch is removed because
one of the hinges is seized. It had a second fuel tank at one time and the hole
below the rear side window is still present. Some of the glass has minor
pitting from the sand blasting.
The input seal on the transmision is leaking as well.
The vehicle is very sound in regards to all the mechanical aspects. It runs
well, It has a comfortable ride and brakes well. I originally planned on fully
restoring this vehicle and took special care to make sure things were done
properly. My goals and interest have changed so I regretfully need to find
another home for the vehicle. There are probably many other new parts that
I have forgotten to list but you can get a good idea of its condition what the
list above. My asking price for the vehicle is $12500
Possible trade for high mpg car or sprinter van
Keyword, fj40 fj45 fj 40 land cruiser fj45 4x4
