- Location
- United States
I am moving out of the country so I must sell! Here are the specs
Chevy 327(runs great carb needs adjusted)
stock 3 speed
stock transfer case
Back axle: stock with a spring over and sits on a new 3in lifted jeep cherokee springs with all new poly bushings. new rancho 5012's on all four corners
Front axle: is out of a 1985 toyota mini pick up
springs up front are new and from a jeep wrangler with new poly bushings. there has also been a shackle reversal done.
Steering: new trail gear high steer set up that conncets to a saginaw power steering box.
Brakes: new calipers and pads and extended lines up front as well as new hard lines
Electrical: all new 18 curcuit wiring harness for E-Z wiring. every switch is new as well as every bulb. MSD 6al ignition with blaster 2 coil.
Cooling: New radiator. New 16in electric fan with new switch
Recovery: XD9000i with new 100 ft of plazma rope. 48in high lift jack
Wheels and tires: new 36in super swamper iroc's with 36 bolt bead lock wheels
Other things that are new: poly gas tank, new clutch master and slave cylinder
The truck currently has good soft top and doors.
This truck also comes with: hard top (needs alot of work) hard doors. two toyota C/V drive shafts and a toyota mini pick up rear axle
The Frame on this truck is in great shape no rust to speek of. the body is straight and the only rust that is visible is on the cross member that is in front of the back wheel well
This truck is being sold as is there are sum minor thing that need to be adressed: they are as follows, turn signal indicators in the cab need to be wired. hazard switch needs to be wired. amp and fuel gages need to be wired(I have all the parts the labor just needs to be done.) the carb needs to be adjusted and the brakes need to be blead again. I'm located in medford NJ 08055 and I can be reached at 609-744-4443 thank you for looking. The sum of the parts are almost equal to my asking price. if you would like photos please contact me and I will e-mail them to you right away. ( cant get my current photo to resize small enough
Keith
stock 3 speed
stock transfer case
Keith
