Ok. Thank you to all that have contributed. So I talked to Chris at Alpha today. Apparently the guy I spoke with yesterday was confused and thinking about a 100 series that does have vastly different hubs.So I tried again to pull the trigger on a set of 17” rims for my ‘13 LX. Been looking for RW for about 4 years with no luck as I would like to stay as close to OEM filament as possible. Had a set of method 703’s 17” +35 on order since September. Just got word that tire rack has some alpha equipt rims on close out. So went to Order the alpha COMMAND in 17”x8.5 +35 for $159/rim. Tire rack said it won’t fit. I called Alpha Equipt directly they also said the tundra so the wheel won’t fit due to the 200 having a larger front hub bore
Also anyone have the Alpha Equipt wheels on a 200?
LX gooks good on 34's. I've ran KO2's on all my trucks but thinking of going with the Toyo AT3's. hope youre enjoying to ride !Winter is going on too long and I got impatient. Figured I rarely drive the LX in the winter so would go ahead and switch to my new summer set up. The alphaEquipt fit and look great. Couldn’t get Defenders so went with KO2s. Had to do some major mud flap work with the heat gun and zip ties due to less offset I’ll probably end up taking them off.
I had to heat and zip tie the front fenders. No issues.LX gooks good on 34's. I've ran KO2's on all my trucks but thinking of going with the Toyo AT3's. hope youre enjoying to ride !
no problems/rubbing with the 285/75/17 so far ? reviving this thread haha
Did you end up leaving the mudflaps on? A heat gun and zip ties were enough to get the mud flaps out of the way for the 285/75/17?I had to heat and zip tie the front fenders. No issues.
Yes Mud flaps are still on.Did you end up leaving the mudflaps on? A heat gun and zip ties were enough to get the mud flaps out of the way for the 285/75/17?
Could i bother you for a photo of what this looks like done? Ive been going down the rabbit hole for this tire size and seeing such contradicting posts on the trimming and mud flap removal needed to accommodate this sizeYes Mud flaps are still on.
I have my winter tires/wheels on currently that are ~30” OD. (265/60-18). So it will have more space then my summers. With the way winter is going here in Alaska I probably won’t switch back to my summers until late May.Could i bother you for a photo of what this looks like done? Ive been going down the rabbit hole for this tire size and seeing such contradicting posts on the trimming and mud flap removal needed to accommodate this size
