17 inch FJ Cruiser wheels on a 95 Landcruiser (1 Viewer)
I have looked for the offsets of each to compare but I didnt find much. Anyone know if they will work with a 33 inch tire and 3 inch lift?
I have the FJC rims on my stock '92. No spacers and no issues. I've read that you can stuff a 35 in there without a lot of issues unless you're doing some serious flexing on rocks etc.
Your truck came stock with 16x8 rims with 0mm inset( the centerline of the wheel is also the location of the mounting face).
The FJC rim is a 17x7.5 with a 15mm inset( the centerline of the wheel is 15mm inboard of the mounting face).
Depending on the width of the tire, you should be OK.
For looks , you might consider some spacers to bring the tire out a bit.
imo the stock 80 wheels don't sit out far enough. I believe they are a 15mm offset 16x8. FJC wheels are 17x7.5 with a 15 mm offset. same offset but because the wheel is skinnier it sits even further inside. spacers would allow you to use center caps and would bring it out flush with the fenders
There is a guy in our club that runs those wheels on his FJ80 with 25575R16 and they look real good. They sit in a little more than the stock 80 wheels but that was the look he was going for and also got the wheels at a good price.
His MUD name is Motleyone but I couldnt find a picture of his truck.
