16'+ LX570 WHEEL CHOICE AND TIRE SIZE
Dallas, TX
Assume they will be wrapped in K02 in the largest size that does not rub at all in normal mode. (Please include tire size if you know what will fit the spec!)
1. Which is best?
A. METHOD 314 - 17x7.5, 25 offset (26.4lbs/wheel, 3640lb load)
B. METHOD 705 - 18x9, 25 offset (28.9lbs/wheel, 2650lb load)
C. Vector 5 - 17x8.50, 25 offset (30lbs/wheel, 2750lb load)
D. AM I MISSING A BETTER OPTION? My goal is to keep relatively subtle on the looks...
Much appreciated!
I put EvoCorse DakarZero +40mm offset 17X9 wrapped in 285/70r17 ko2s on my 2010 lx. One of the best and strongest wheels you can get other than custom Braid rally wheels. The closer to factory offset you can stay the better. Just my .02.
