Some 7* series had 15 inch rims and I had some 15x8. But what does the 20s mean? Personally, I would stick with 16 in wheels. The choice of 15 inch tyres gets slimmer every year.
Hi all, i've got aftermarket 16s on my 91 HZJ77 and have found some oem 15x7-20s. curious if anyone knows if they will have fitment issues?
thanks
bret
The “-20” is referring to the offset of the rim but he really should be more focused on what the BS of the rim is.
Seems like most have success with 3.5 to 3.75 BS before spacers come into the picture on most 70 series.
If I am doing the math right and assuming the upper and lower flanges are .5" each, these seem like they are 3.2 BS being 15X7 -20.
Hello,
x2.
There are more options with 16 and 17 inch wheels.
Juan
If they are OEM, why are you worried about fitment issues?
Im aware of this , that why Im trying to get some more info about exactly what his doubts are
if you are aware than you know what my doubts are?
You never told us where the wheels come from, except they they were OEM. Now you tell us they are off a HZJ75. A little research would tell you all the 7*series leaf sprung vehicles are basically the same vehicle except for the length . Its a model toyota designed to be able to share a wide range of parts from other 7*. They didnt make special wheels for the 77 series, so next time tell us the full story and you will beat the auction dead line
Because the axle, frame and body widths are all the same 84-90. And I have had both 15 and 16 inch rims on my 73 , 75 and 61 series and never had an issue.
The only difference I could see is where some of them protrude from the body a little which were are covered by the fibreglass flares.
But its gets back to the fact if they came off a 75 , you wont have a problem putting them on a 77.
The 7* series leaf sprung models all have a track width of 1415mm front and 1400mm rear (same as a 55 series)
But maybe they didnt come off a 75 series as claimed.
i said they were off a 75 in my first response. Regardless, If it's true that they are all interchangeable then why would the 15x7-20 have potential backspacing issues as noted above by @FJ73Texas? If i need more backspacing than they are not all interchangeable.
You can still buy new 7* series steel rims in the 16in size, a much better proposition IMO
I missed that they came off a HJ75 originally. 3.2 very close to 3.5 anyways.
Either way I agree that going up to a 16 or even 17 is better choice overall.
I believe those online OEM shops sell them, no idea on how much they cost.Are they easy to get state side?
