My Oldtoy has slight hesitation on acceleration, mainly around 1300-1800rpms, more noticeable when I manually throttle from engine itself and keep revs at that range, if I rev or juice up past that point no issue? The funny thing is when tank is low it the 13bt considerably runs smoother, and when tank is full the hesitation is noticeable and doesn't seem to run as well compared to low tank.
I been reading up past posts on hesitation but still a little green, so I intend to start with basics
1, replacing vacuums lines
2, replace fuel lines/ or check for air leakage
3, drop tank and check for muck at pick up
Other points that pricked my attention was something crusher has mentioned regarding a ripped diaphragm, ?.? Not sure where??
When starting I need to give a little pedal support to get some juice in prior to starting and manually twist throttle up to keep revs at about 800rpms, if not it's like a cage fight in my engine bay when sitting overnight, (15 degrees amb.).......when engine warm still has little minor hissy fit prior to Idle without any pedal support, .....with-pedal support fires up great and lands at idle. If any other mudders have had hesitation with 13bt, your feedback, solutions are most welcome.
Ch ch ch cheers
Ch ch ch cheers
